170 engine suffix ? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: 170 engine suffix ?Posted: 06 Oct 2012 at 5:10pm |
What does the letter M, and Z mean at the end of engine serial number? Thanks Tracy Martin |
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 06 Oct 2012 at 6:41pm |
M code engins are found in most D17's, 170's and Gleaner E111's have a little more compression an those are z code. D 17 lp and 175's have even more compression and are V code engines.
Tracy Martin TN
Posted: 06 Oct 2012 at 8:30pm |
I was wondering. I have an M code and 2 that have the Z code. Thanks Tracy Martin
DanD
Posted: 06 Oct 2012 at 8:36pm |
The M code is 7.2:1 compression ratio. The Z is 8.0:1 and the V is 8.2:1. Of course all that's different in the engines to change the ratios is the piston heights, so who knows what is actually inside on a 35 to 50 year old engine. I know of an M engine for example, with 8.2:1 pistons in it.
