170 capabilities
Nick in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick in MI Quote  Post ReplyReply Direct Link To This Post Topic: 170 capabilities
    Posted: 24 May 2010 at 5:36pm
Just curious how big of impliments my 170 gasser can handle in loam/clay, like what size 1200 field cultivator or 2200 disc? Also will a d-19 diesel handle a six row corn planter in the same soil? thanks
Ashes to ashes, dust to dust, if it weren't for John Deeres our tools would rust
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:20pm
I'm sure the other will correct me if I'm wrong but my guess is you need to put the planter on the 170 and hook the tillage tools to the D-19.   The 19 should have the most power of the two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:26pm
My 180 is a bit bigger in HP and bulk, I pull a old JD 4 row planter with ease, a eight foot Bush hog mower or a 12 foot IH disc(2200#).  I have not put a bottom plow behind it as yet but I suspect it will do a 3 bottom 14" fairly readily.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:12pm
The 170 should be good for 12 ft disc as it is rated at 54 hp drawbar
Farm stuff 8050,6690,175,F2,5050,WD
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:18pm
A  D-17 gas can handle 3-14" plow in some pretty tough going.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:29pm
I used to pull a 6row  International  planter with a rake on it with a WD45  that was overbored and had duals. Also some of the ground was muck.
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:30pm
We also have a D-17  Series IV  pulled 4 -14" mounted, light front end and not great on rolling ground.  Went to 3 -16" with crowfoot packer and did a great job.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:05pm
Have no problem pulling a 22" breaking plow (modified from a trip bottom to an Allis SC hitch comliments of a parts plow and the local fab shop) and a 16' John Deere disc (12" discs, tandem gangs) with my D19D. Its a brute.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick in MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:50pm
k I was just curious cuase id like 2 get a field cultivator to match either the 170 or 19 along with a lighter disc to put in soy beans and wheat cuase i cant afford to upgrade to a notill drill for a while, but im getting ready to buy a no-till corn planter and would like to get a 6 row (if the 19 will handle it) now instead of a 4 row for the 170 so i wont have to upgrade as fast when i grow in acerage.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 10:07am
We pull 4 18 plow and 16 foot disc with D-19. I have pulled a 6 row 7000 John Deere with A D-12 handels it just fine and we live in the Hills.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 10:34am
KY,  you are thinking like I am.  I'm pretty certain I could pull a 6 row planter behind a D-14 with no problem whatsoever.  I can't see why a 170 couldn't pull it like there was nothing back there.  That leaves the D19d to do the heavy lifting.
This page was generated in 0.053 seconds.
