170 capabilities |
Nick in MI
Topic: 170 capabilitiesPosted: 24 May 2010 at 5:36pm |
Just curious how big of impliments my 170 gasser can handle in loam/clay, like what size 1200 field cultivator or 2200 disc? Also will a d-19 diesel handle a six row corn planter in the same soil? thanks
Ashes to ashes, dust to dust, if it weren't for John Deeres our tools would rust
Charlie (NC)
Joined: 12 Sep 2009 Location: Coastal NC Points: 942 |
Posted: 24 May 2010 at 6:20pm |
I'm sure the other will correct me if I'm wrong but my guess is you need to put the planter on the 170 and hook the tillage tools to the D-19. The 19 should have the most power of the two.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34955 |
Posted: 24 May 2010 at 6:26pm |
My 180 is a bit bigger in HP and bulk, I pull a old JD 4 row planter with ease, a eight foot Bush hog mower or a 12 foot IH disc(2200#). I have not put a bottom plow behind it as yet but I suspect it will do a 3 bottom 14" fairly readily.
wheatbreeder
Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 581 |
Posted: 24 May 2010 at 7:12pm |
The 170 should be good for 12 ft disc as it is rated at 54 hp drawbar
Farm stuff 8050,6690,175,F2,5050,WD
Stanley
Posted: 24 May 2010 at 7:18pm |
A D-17 gas can handle 3-14" plow in some pretty tough going.
Lester
Posted: 24 May 2010 at 7:29pm |
I used to pull a 6row International planter with a rake on it with a WD45 that was overbored and had duals. Also some of the ground was muck.
snowman(MI)
Joined: 12 Sep 2009 Location: Sand Lake, MI Points: 384 |
Posted: 24 May 2010 at 7:30pm |
We also have a D-17 Series IV pulled 4 -14" mounted, light front end and not great on rolling ground. Went to 3 -16" with crowfoot packer and did a great job.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 24 May 2010 at 9:05pm |
Have no problem pulling a 22" breaking plow (modified from a trip bottom to an Allis SC hitch comliments of a parts plow and the local fab shop) and a 16' John Deere disc (12" discs, tandem gangs) with my D19D. Its a brute.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Nick in MI
Posted: 24 May 2010 at 9:50pm |
k I was just curious cuase id like 2 get a field cultivator to match either the 170 or 19 along with a lighter disc to put in soy beans and wheat cuase i cant afford to upgrade to a notill drill for a while, but im getting ready to buy a no-till corn planter and would like to get a 6 row (if the 19 will handle it) now instead of a 4 row for the 170 so i wont have to upgrade as fast when i grow in acerage.
KY
Posted: 25 May 2010 at 10:07am |
We pull 4 18 plow and 16 foot disc with D-19. I have pulled a 6 row 7000 John Deere with A D-12 handels it just fine and we live in the Hills.
Charlie (NC)
Posted: 25 May 2010 at 10:34am |
KY, you are thinking like I am. I'm pretty certain I could pull a 6 row planter behind a D-14 with no problem whatsoever. I can't see why a 170 couldn't pull it like there was nothing back there. That leaves the D19d to do the heavy lifting.
