170, 175 hydraulics
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Topic: 170, 175 hydraulics
    Posted: 04 Oct 2023 at 7:18pm
it has been a while. phone went down lost all notes and photos on repairs. but that's another story. Trying to remember what to do or how to clean valve on the traction booster or lift arm valve. This is to allow the lift arms to stay in the lower position, instead of creeping up or staying up. would ask bill from sandy lake but he has retired.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 7:55pm
If the 3 pt arms come up when the tractor is started and won't go back down, you have a stuck traction booster spool valve. Move the traction booster and depth control levers all the way forward. Make sure all the pivots on the linkage is free to move. From the rear, take the cap off the spool closest to the fender and with a punch gently tap it forward. The arms will drop. Unless you need the TB for plowing, don't mess with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 9:08pm
moving round bales off field and mowing hay.  need spear to go down to stab bales, and need to mow hay close to ground. thanks rick. the valve needs to be cleaned dirt and dust accumulate on plunger
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 5:47am
Traction Booster linkage, Position Control linkage and the hydraulic spool/plunger itself are all potential problems to "stick" when not used often. There's only one hydraulic spool/plunger that is controlled by two sets of linkages: TBoost and Position control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 6:53pm
thanks again, my uncle was pleased we were able to have the lift arms moving under his control. took cap off back of spool, moved plunger forward, put a 3/8" impact with 1/2" socket to turn plunger to remove dirt, dust and oil build up off with brass brush.
This page was generated in 0.166 seconds.
