170/175 Block Heater
farminharmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Topic: 170/175 Block Heater
    Posted: 19 Jan 2017 at 1:54pm
Anybody got a picture of the block heater location on their 170 or 175?
B110 CA D10II (2)D12III 5040 5050 6080 170
JD5205 Kubota M9000 Kubota M95S
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 4:44pm
I can email you one but can't post here from my iPad
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 5:24pm
On the 248 Perkins, you can see one frost plug hole open here.  That is where the original block heater was - it is in behind the starter when everything is together.  I took mine out since it was leaking and the tractor does not get used in the winter.
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 7:20pm
Our 175 with the 4.248 engine had the external style coolant circulation heater. Mounted on RH frame rail with a hose to water pump one way and rear coolant drain plug of engine block the other way. Took it off cause it started leaking and we don't need it anyway.
