16B undercarriage ? |
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Topic: 16B undercarriage ?Posted: 23 Oct 2016 at 11:15am |
Im looking for an u/c for 16b, someone is parting out a
12g. Is that u/c the same as 16b? Anyone know of any other Machine u/c parts that fit? Two people have told me there is sprocket segments that are still made that are tight but fit. A salvage yard in Missouri that deals with alot of allis has a good u/c, I've called twice and he never would give me a price or call back and now i dont have there number any more. I have 12 different wtb ads on craigslist heavy equipment and basically no calls. I know somewhere out there in the southeast is one sitting with trees growing around it but i cant find one to still a good bottom from. |
gemdozer
Posted: 23 Oct 2016 at 1:11pm |
Yes the 12gb use the same chaines ,rollers, idlers and the same sprocket segments than
HD16B
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35312 |
Posted: 23 Oct 2016 at 7:25pm |
Will be same. 7.85 pitch
Lazyts
Posted: 23 Oct 2016 at 7:41pm |
http://www.kijiji.ca/v-heavy-equipment-machinery/winnipeg/allis-chalmers-hd-16-pins-bushings/1177553422?enableSearchNavigationFlag=true
I looked at a 16B a couple of years ago. At that time Stephens Equipment in PA had a set of segments for one (from 12G). 1-800-567-3086 |
DMiller
Posted: 24 Oct 2016 at 6:08pm |
I wonder if Deere or Cat 7.984 would work with a smaller bushing diameter and some wear to the sprocket teeth?
difference is less than the 6.906 I can use on my 7G. .066 as opposed to .094. Another option, weld the bolt holes shut to redrill for Cat or Deere segments
to drop to 7.484 rails or weld a segment ring from a Cat for their segments.
Edited by DMiller - 24 Oct 2016 at 6:36pm |
