160 Self Starting
elbyCJett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elbyCJett Quote  Post ReplyReply Direct Link To This Post Topic: 160 Self Starting
    Posted: 03 Feb 2017 at 6:05am
No pictures ...
I picked up a set of suitcase weights for my 160 this last week end.  I asked the seller why they were being sold.  He shared this story ...
They had a nice 160 Allis Chalmers.  They had used it and parked at the end of the day.  Not long after parking it, their dad 86 years old observed the 160 ambling by itself across a field and run into their "big tractor".  It caught fire.  The dad got to the two tractors and was able to back the 160 off of the other tractor.  He saved the "big tractor".  He could not put out the fire and got burned himself in the process.  The 160 was toast.  They scrapped it not thinking the drive train might be salvageable.
I surmise they shut the 160 down and did not pull the stop out.  These Perkins engines start quite easily and can not be left in gear with the stop in especially on a grade.
D-14, 160, 2 - CAs, 2 - Bs, 2 Gs Roto-Baler, 82S Mower, Rake,444 baler, Kentucky
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 6:30am
WOW,, but I have heard of a 7000 starting its self once ; guess it could happen if things get shorted out just right
Edited by DougG - 03 Feb 2017 at 6:31am
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 6:42am
Have personaly seen it neighbor always pulled button out shut it down then pushed it back in for next time it was started parked on the slight hill went in for lunch I see the tractor coming across our fiel as I was culivating with no body on it sgop mine run over and cath it the look back twards his house and see him walking twards me we hada good laughf and lesson learned
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:17am
That is why when my tractors get parked in the garage after I use them I always disconnect the battery cables. At least the ones that have batteries. I know it might not help with a diesel if you park on a grade like you say but I have heard of old wiring causing tractors to start themselves.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:29am
If you put the tractor in reverse when parked on a grade you can be pretty sure it won't fire up.Have seen Detroits run backwards though.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:53am
During my work tenure at west plains implement, it happened twice. One time after everyone was gone except for one salesman and his customer, they were standing outside the building, and a tractor self started and started coming accross the lot towards them. Salesman got it shut down with no harm done. Another time, during the peak of the day an international articulating 4X4 started itself right in shop, but was luckily in neutral. We all heard it start, and just assumed that someone was working on it. After it had been running long enough that it had us all just about smoked out, and we went to chew someone out for running it so long inside, there was nobody there. Never had been. Odd. Darrel
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:57am
Gremlins?
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 8:22am
All the sudden I like my habit of shutting off the gas and parking my tractor in neutral....even though my B probably won't start without me telling it too. Wink
'39 Model B
Tractors are cheaper than girls, remember that!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 9:58am
I always thought it was a poor idea for the fuel shutoff on my 5020 to be spring loaded...
ALLIS EXPRESS!
This year:
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 10:08am
2x I was just thinking the same thing.
As to reverse I have accidentally started a deutz that way trying to roll it back off a bunker silo when it stalled half way up. Guess the clutch wasn't adjusted too good at the time weirdest thing I ever say it was just as happy running backwards as normal
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 11:48am
On my one-sixty, not only do I have to turn the fuel on but have to engage the clutch as there is a safety switch there. Won't start otherwise. Guess I'll maybe start also putting it in neutral, too, when I shut it off. Dave Funny, but as I sit here at the computer, I forget which way I have to move the fuel shut off/on lever (in or out) to turn it on/off, however when I get on the tractor I automatically move it the correct direction!
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 12:44pm
There was a guy around here that parked his combine in the barn in gear one year. A mouse chewed the wires and made a connection to the starter. It started and ran through the side of the barn.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 12:45pm
we have boats that start  or at least crank over quite often when they are left out in the rain uncovered.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
