160 fuel
Mcollier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mcollier Quote  Post ReplyReply Direct Link To This Post Topic: 160 fuel
    Posted: 25 Jan 2026 at 9:35pm
160 fuel problems can anybody help somebody messed with this tractor and definitely didn’t ow what they were doing fuel lines loose broken etc I want to get the plumbing right and a good mechanical pump I should use plus how to prime this thing thanks in advance
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 10:50am
Sediment bowl under tank on LH side behind panel - hose to fuel pump with another sediment bowl - feed line to fuel injection pump. Open both bleed valves - one on curved side of pump and identical one on top of rectangular top cap of CAV pump.  Pump hand pump until only fuel comes from side bleeder and close - continue pumping until only fuel comes from top bleeder. Loosen one injector line with 17mm wrench and turn tractor over until it starts then tighten fuel line. Check for leaks. The other lines are return.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2026 at 10:55am
There is a thread below this addressing the same issue - check the fuel filter to make sure it is the correct filter WITH holes in top - if it is the other style filter it is easy to allow the oring to get into the slots and block fuel flow - just use the correct filter.
