160 Clutch and pressure plate |
Celtic Clamper
Topic: 160 Clutch and pressure platePosted: 24 May 2023 at 8:47am |
Thanks for allowing me on the forum. I am working on a Model 160 for a good friend of mine. His clutch/throwout bearing tore up the fingers on the pressure plate. I am trying to find someone that has at least 1 good finger. I have tried all the usual parts places, but no one has fingers. I am sure that the 6040 uses the same fingers. I am willing to make an extra set for someone if I could just get a good sample. Thanks in advance.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5250 |
Posted: 24 May 2023 at 8:48pm |
I can’t help you with the fingers but make sure you put the clutch shims with the flat side facing out towards the bell housing. It will not release the clutch if you don’t. Rick Corder may be able to help you with finding fingers. He is a member on here.
Celtic Clamper
Posted: 24 May 2023 at 9:35pm |
Thank you AC720MAN. I appreciate the advice. These AC's are so hard to find parts for. I am sure it would be easier if it were a more common model. I can fabricate/machine the fingers if I just had something close. These fingers are so worn that they are about snapped in half.
AC720Man
Posted: 25 May 2023 at 7:41am |
They are getting harder to find parts for due to the low production numbers but they are good little tractors. I really enjoy using mine. So far I have found parts but requires more research than my other AC models. Hope you find some fingers, reach out to Rick, he may be able to help you find some. Out of curiosity how many hours on on this tractor? Mine had 7540 hours on it when I rebuilt the engine and had Rick rebuild both clutches.
Edited by AC720Man - 25 May 2023 at 7:49am |
John WV
Joined: 30 Oct 2010 Location: bunker hill wv Points: 273 |
Posted: 13 Jun 2023 at 6:28am |
AC720Man how do i get a whole of Rick i have one setting on a shelf that needs rebuilding ? got to replace this winter in my 160. she also leaking oil real main seal and i seen in repair book it talked about a plug some place which i never found the last time i was in it.
John WV
Posted: 13 Jun 2023 at 6:32am |
years ago i have gotten fingers from MF dealer for 135 they used same clutch for my 160
Celtic Clamper
Posted: 13 Jun 2023 at 6:52am |
The fingers were for a 135 Massey? Thank you.
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 13 Jun 2023 at 7:10am |
John/WVA...The best thing to do with the unit you have sitting on the shelf would be to send it to Kentucky Clutch in Brooks, KY. and have them rebuild it for you. Good people to work with and do a great job. Celtic Clamper...As for repairing the worn down fingers...a set from a 6140 I'm pretty positive are the same exact thing, so you can look for a unit with good fingers in it and have that core rebuilt...I think I would just save the old core for the parts, because they're not making any more of them, for sure. The Massey 135 clutch unit and the 160 clutch unit are totally 100% different...I doubt they're an exact interchange...Rick
John WV
Posted: 13 Jun 2023 at 10:33am |
Rick, thanks for the information
ac-mike
Posted: 13 Jun 2023 at 11:51am |
I agree with Rick. Send to Ky Clutch or better yet take it there along with flywheel, clutch throw out bearing, pilot bearing, and allow them to set everything right. They should have everything you need and are very knowledgeable.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
John WV
Posted: 13 Jun 2023 at 12:16pm |
ac mike good ideal but cost a lot to ship and its almost 600 miles from me clutch i can handle but fly wheel weights alot
AC720Man
Posted: 13 Jun 2023 at 2:50pm |
That is one of the heaviest flywheels I’ve ever picked up John, I know what you mean about shipping. I had a local shop do mine while Rick did my clutch. A good local shop should be able to handle that.
John WV
Posted: 14 Jun 2023 at 4:43pm |
yes she is heavy last time i wasin the 160 i took the flywheel off
Rick
Posted: 14 Jun 2023 at 5:06pm |
John WV...Take the flywheel to a more localized reputable shop and have them do that for you...would be a lot cheaper than shipping it across country both ways! LOL!
John WV
Posted: 16 Jun 2023 at 6:58am |
rick thanks
Rick
Posted: 16 Jun 2023 at 7:34am |
You're welcome, John!
