160 Ball Joint |
FarmerJohn22 ![]() Bronze Level ![]() ![]() Joined: 05 Nov 2013 Location: Fall City, Wa Points: 78 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Mar 2025 at 2:20pm |
The ball joint on my 160 won't stay in the socket anymore. It looks like the ball joint is supposed to be a replaceable part, but I'm having a hard time finding it. Does anybody have a source for it? Thanks.
1953 CA, 1950 G, 1970 160
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
If your mean the left one I use Case part # K207722 cut the old one off then drill hole in the rod weld the new one in or tap threads
pump grump ![]() Bronze Level Access ![]() Joined: 11 Mar 2012 Location: dayton oregon Points: 31 |
The last two I got from Agco .
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5232 |
I’ve had good luck calling my AGCO dealer to find out if they are still available, if NLA they will search the dealer network to see if anyone has any and give me the phone number to call to purchase it. 160 parts are getting hard to find unfortunately but I have been lucky so far.
Farmer John 22 , did you find your ball joints for your 160 ?
Not yet. Thanks to your and ACMan's advice, I called around to a couple of the AGCO dealers around. It took me a little bit to find one that was willing to help, but I talked to one today that is looking for the parts for me, so we will see how that goes.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4739 |
I had good luck with Dale At FEH in Pendelton .
Well I found a dealer that was willing to help me. It looks like a couple of the parts are still available, and they were able to find one of the other parts, but apparently they can't find the actual ball and pin part, or the ball cage, so I guess maybe I'll have to try to find a ball joint that has the same pin size that I can use.
