| Author |
Topic Search Topic Options
AJ
Topic: 160 Advice Posted: 30 Sep 2012 at 10:05am |
I am thinking of getting a 160 in the future sometime because I believe it may be a good all around tractor. 1. What are the pros and cons of the 160? 2. Also, how common are the 460 loaders for them and is there other allis loaders for it? 3. What are the values of the 160's (pending the shape obviously)?
Can't fix stupid
barky
Posted: 30 Sep 2012 at 7:03pm |
Parts arte hard to get, I would stay away from them.
CTuckerNWIL
Posted: 30 Sep 2012 at 7:30pm |
barky wrote:
Parts arte hard to get, I would stay away from them. | http://www.mainetractors.com/allis%20chalmers%20160%20tractor/allis%20chalmers%20160%20tractor.htm| Sold |
Part # |
0 |
Allis Chalmers 160
(2) |
Used Price |
LBS |
2072636 |
A |
Air Cleaner Asy |
$75.00 |
2011 |
2080138 |
A |
Camshaft |
$100.00 |
2011 |
31415260 |
2080139 |
A |
Camshaft Gear |
$30.00 |
8 |
2011 |
50T |
| Sold 1 |
A |
Crankshaft |
$200.00 |
2080095 |
A |
Crankshaft Gear |
$0.00 |
| Sold 1 |
2080097 |
A |
Crankshaft Pulley |
$90.00 |
2011 |
2080329 |
A |
Crankshaft Pulley |
$90.00 |
2011 |
| Have 1 |
2080000 |
A |
Cylinder Block Diesel |
$500.00 |
2012 |
Perkins C3711210 |
| Sold 1 |
2080000 |
A |
Cylinder Head |
$235.00 |
2011 |
2080041 |
A |
Cylinder Head |
235.00 |
2011 |
2080110 |
A |
Cylinder Head Cover |
$20.00 |
3 |
2011 |
| Sold 1 |
2080033 |
A |
Engine Mounting Bracket RH |
$45.00 |
2011 |
| Sold 1 |
2080034 |
A |
Engine Mounting Bracket LH |
$60.00 |
2011 |
| Sold 1 |
2080235 |
A |
Fuel Lift Pump |
$45.00 |
| Sold 1 |
251315 |
A |
Fuel Filter Head & Base |
$65.00 |
2011 |
| Sold 1 |
2080140 |
A |
Idler Gear |
$250.00 |
2011 |
0410134, 90T |
| Sold 1 |
2080274 |
A |
Injector Pump |
$400.00 |
2011 |
31164440 |
A |
Injection Pump Drive Gear |
$55.00 |
2011 |
50T |
| Sold 1 |
2080071 |
A |
Manifold Exhaust |
$0.00 |
| Sold 1 |
2080133 |
A |
Manifold Intake |
$45.00 |
2011 |
2080206 |
A |
Oil Filter Canister |
$100.00 |
2011 |
| Sold 1 |
2080177 |
A |
Oil Pan |
$240.00 |
2011 |
37171700 |
| Sold 1 |
2080189 |
A |
Oil Pump Asy |
$80.00 |
2011 |
| Sold 1 |
2080104 |
A |
Piston |
$50.00 |
2011 |
| Sold 1 |
31337220 |
A |
Connecting Rod |
$50.00 |
2011 |
2080120 |
A |
Rocker Arm Asy |
$55.00 |
2011 |
2080145 |
A |
Timing Gear |
$.00 |
2080163 |
A |
Timing Gear Cover |
$100.00 |
2011 |
2080145 |
A |
Timing Gear Housing |
$80.00 |
2011 |
| Sold 1 |
2080232 |
B |
Fan |
$30.00 |
4 |
2011 |
| Sold 2 |
2073285 |
B |
Radiator |
$225.00 |
2011 |
| Sold 1 |
2080215 |
B |
Water Pump Asy |
$65.00 |
2011 |
D9003715 |
2072545 |
C |
Main Shaft 5th Gear |
$80.00 |
2011 |
32T |
2072546 |
C |
Pinion Shaft 5th Gear |
$155.00 |
2011 |
27T |
2072522 |
C |
Range Control Gear |
$95.00 |
2011 |
18T, 21 Splines |
2072548 |
C |
Main Shaft 6th Gear |
$80.00 |
2011 |
38T |
2072829 |
C |
Clutch Housing |
$155.00 |
2011 |
2072846 |
C |
Clutch Housing Bearing Guide |
$50.00 |
2011 |
| Sold 1 |
830641 |
C |
Clutch Release Bearing |
$100.00 |
2011 |
| Sold 2 |
2073558 |
C |
Clutch Plate Asy |
$220.00 |
2074250 |
C |
Clutch Shaft & Fork Asy |
$65.00 |
2011 |
2072521 |
C |
Clutch Shaft |
$90.00 |
2011 |
2072796 |
C |
Clutch Shaft |
$90.00 |
2011 |
2072840 |
C |
Clutch Sleeve |
$70.00 |
2011 |
| Sold 1 |
C |
Flywheel Adapter Plate |
$0.00 |
| Sold All |
2072960 |
C |
Flywheel Asy
w/Ring Gear |
$370.00 |
2011 |
2072693 |
C |
Flywheel Housing |
$105.00 |
2011 |
2072548 |
C |
Pinion Shaft 6th Gear |
$135.00 |
2011 |
24T |
2072434 |
C |
Synchronizer Asy |
$105.00 |
2011 |
2074390 |
C |
Pinion Shaft Sliding 3rd & 4th |
$190.00 |
2011 |
29T, 33T |
| Sold 1 |
2073509 |
C |
Reverse Gear |
$0.00 |
| Sold 1 |
2072446 |
C |
Reverse Shaft |
$0.00 |
2074399 |
C |
Range Control Lever |
$80.00 |
2011 |
| Sold 1 |
C |
Shift Cover w/Forks |
$200.00 |
2010 |
2072527 |
C |
Range Gear Shaft |
$65.00 |
2011 |
2072525 |
C |
Range Gear Intermediate |
$70.00 |
2011 |
16T, 33T |
2074360 |
C |
Reverse Idler Gear |
$160.00 |
2011 |
13T, 15T |
2072511 |
C |
Range Gear |
$80.00 |
2011 |
36T, sn To 144400 |
2072536 |
C |
Range Sliding Gear |
$230.00 |
2011 |
35T External, 18T Interior |
2072431 |
C |
Pinion Shaft Sliding Gear (1st
& 2nd) |
$195.00 |
2011 |
37T, 41T |
| Sold 1 |
2072432 |
C |
Sliding Gear (3rd
& 4th) |
$250.00 |
2011 |
| Sold 1 |
2073943 |
C |
Sliding Gear (3rd
& 4th) |
$250.00 |
3 |
2011 |
18T, 22T |
2073931 |
C |
Shift Fork 3rd & 4th |
$80.00 |
2011 |
2073932 |
C |
Shift Rod 3rd & 4th |
$85.00 |
2011 |
| Sold 1 |
2072401 |
C |
Transmission
Housing |
$225.00 |
2011 |
2074345 |
C |
Transmission Housing |
$225.00 |
2011 |
2072413 |
C |
Transmission Input
Shaft |
$650.00 |
2011 |
| Sold 1 |
2074389 |
C |
Transmission Main
Input
Shaft |
$650.00 |
6 |
2011 |
21 Splines, 14T, 10T |
2072529 |
C |
Transmission
Splined Coupling Sleeve |
$155.00 |
2011 |
6 External Splines, 21 Interior Splines |
2073846 |
D |
Hydraulic Reservoir |
$50.00 |
2011 |
| Sold 1 |
2072605 |
D |
Hydraulic Manifold |
$265.00 |
2011 |
| Sold 2 |
2074076 |
D |
Hydraulic Pump |
$250.00 |
2011 |
2073320 |
D |
Hydraulic Oil Filter Asy |
$65.00 |
2011 |
sn To 144137 |
| Sold 1 |
2072858 |
D |
Hydraulic Lift Housing |
$205.00 |
2011 |
sn To 145166 |
| Sold 2 |
2072663 |
D |
Hydraulic Remote Valve Asy |
$370.00 |
12 |
2011 |
| Sold 1 |
2073578 |
D |
Hydraulic Position Control Valve |
$520.00 |
2011 |
sn To 144400 |
| Sold 1 |
2072805 |
D |
Lift Arm Asy Right |
$185.00 |
2012 |
Adj. RH Lift Link |
2073317 |
D |
Hydraulic Semi Adj. LH Lift Link |
$100.00 |
2012 |
| Sold 2 |
D |
Draft Link |
$90.00 |
2012 |
| Sold 1 |
D |
RH Lift Link |
$150.00 |
2012 |
| Sold 1 |
D |
LH Lift Link |
$100.00 |
2012 |
2074412 |
D |
Hydraulic Lever Arm |
$85.00 |
2011 |
207855 |
D |
Lift Arm Right |
$60.00 |
2011 |
2072982 |
D |
Hydraulic Sensing Arm RH |
$145.00 |
2011 |
2074409 |
D |
Hydraulic Lift Arm RH |
$60.00 |
2011 |
2072856 |
D |
Lift Arm Left |
$60.00 |
2011 |
2074407 |
D |
Hydraulic Lift Arm LH |
$60.00 |
2011 |
2072983 |
D |
Hydraulic Sensing Arm LH |
$145.00 |
2011 |
2072858 |
D |
Lift Housing |
$205.00 |
2011 |
sn To 145166 |
2072752 |
D |
Hydraulic Quadrant Support |
$60.00 |
2011 |
2073572 |
D |
Lift Housing Plate |
$80.00 |
2011 |
| Sold 1 |
2072869 |
D |
Piston |
$45.00 |
2011 |
2073999 |
D |
Hydraulic Piston |
$45.00 |
2011 |
3.197" |
2072971 |
D |
Hydraulic Sensing Shaft |
$100.00 |
2011 |
2072877 |
D |
Rockshaft, Lift
Arm Shaft |
$0.00 |
2073736 |
D |
Shaft & Pump
Support |
$30.00 |
2011 |
2073256 |
E |
Front Axle Asy |
$0.00 |
2073168 |
E |
Front Axle Support |
$0.00 |
| Sold 1 |
E |
Front End |
$0.00 |
| Sold 1 |
2072551 |
E |
Front Axle Extension LH w Spindle |
$190.00 |
2011 |
270038 |
| Sold 1 |
2072549 |
E |
Front Axle Extension RH w Spindle |
$190.00 |
2011 |
270038 |
261418 |
E |
Front Hub |
$50.00 |
2011 |
| Sold 1 |
2073328 |
E |
Power Steering
Cylinder Asy |
$380.00 |
2011 |
| Sold 2 |
2073327 |
E |
Power Steering
Pump |
$220.00 |
12 |
2012 |
Casting # 34840,
| Sold 1 |
2073363 |
E |
Power Steering Ram |
$0.00 |
2072692 |
E |
Steering Arm LH |
$95.00 |
2011 |
2073798 |
E |
Steering Arm RH |
$110.00 |
2011 |
| Sold 1 |
E |
Steering Ram |
$0.00 |
2073816 |
E |
Steering Shaft Asy |
$218.00 |
2011 |
| Sold 1 |
2073737 |
E |
Steering Valve Asy |
$500.00 |
2011 |
2073704 |
F |
Differential Asy w Ring & Pinion |
$650.00 |
2011 |
| Sold 1 |
2073236 |
F |
Differential Bevel
Gear |
$0.00 |
| Sold 1 |
2073226 |
F |
Differential
Housing |
$275.00 |
2011 |
sn Break = 2073948 141695 to 144799 |
2073149 |
F |
Differential Housing Cover |
$70.00 |
2011 |
2072826 |
F |
Final Drive Left
Sleeve |
$205.00 |
2011 |
2074873 |
F |
Final Drive Sleeve LH |
$205.00 |
2011 |
2072828 |
F |
Final Drive Right
Sleeve |
$205.00 |
2011 |
2074428 |
F |
Final Drive Sleeve RH |
$205.00 |
2011 |
| Sold 1 |
2072934 |
F |
PTO Drive Shaft
Gear |
$155.00 |
2011 |
32T |
| Sold 1 |
2072838 |
F |
PTO Input Shaft |
$175.00 |
2011 |
sn To 143594, 10 Splines, 14T |
| Sold 1 |
2072943 |
F |
PTO Shaft Rear
Interior Gear |
$0.00 |
2010 |
| Sold 1 |
2072949 |
F |
Rear Axle |
$480.00 |
2011 |
2072808 |
F |
Rear Axle Gear |
$140.00 |
2011 |
2074427 |
F |
Rear Axle Gear |
$140.00 |
2011 |
| Sold 1 |
2073610 |
G |
Fuel Tank |
$0.00 |
| Sold 1 |
2073212 |
G |
Hood |
$0.00 |
2073140 |
G |
Platform RH |
$60.00 |
2011 |
2073139 |
G |
Platform LH |
$30.00 |
2011 |
2072956 |
G |
Starter |
$110.00 |
2011 |
| Sold 2 |
2073702 |
G |
Tachometer Asy |
$50.00 |
| Sold 1 |
G |
Wire Harness |
$110.00 |
| Sold 1 |
2073131 |
C |
Engine Frame Left
Side |
$0.00 |
| Sold 1 |
2073132 |
C |
Engine Frame Right
Side |
$0.00 |
2073546 |
H |
Brake Clevis Asy |
$85.00 |
2011 |
2073623 |
H |
Brake Plate Asy |
$120.00 |
2011 |
2073976 |
H |
Brake, Left Cover |
$70.00 |
2011 |
sn 141695 Up |
2073974 |
H |
Brake, Left
Housing |
$190.00 |
2011 |
sn 141695 Up |
2073072 |
H |
Brake, Right Cover |
$70.00 |
2011 |
2073975 |
H |
Brake Housing Cover RH |
$70.00 |
2011 |
sn 141695 Up |
2073065 |
H |
Brake, Right
Housing |
$190.00 |
2011 |
2073973 |
H |
Brake Housing RH |
$190.00 |
2011 |
sn 141695 Up |
DougG
Posted: 30 Sep 2012 at 8:19pm |
AWW they are nice tractors , very peppy and nice speeds , some parts are a little hard to get as they were made in France at the time - Agco has most and the others can be found from places here on the Internet ; 460 loaders are very common , alot of them out there , im really not sure the models that fit a 160 , but i know they had them , ive seen them from 2500 rough condition to 6500 for nice ones , if its decent running and decent tires , id say around 3500-4500 ; tires are a big factor now as they really have jumped up in price , overall there pretty tough good little tractors
