16.9 - 28 Tiires on a WD45
Sanchez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sanchez Quote  Post ReplyReply Direct Link To This Post Topic: 16.9 - 28 Tiires on a WD45
    Posted: 07 May 2020 at 9:00pm
I'm pretty sure 14.9-28 is correct for the WD45 but I have seen a few used sets of 16.9-28 advertised locally. Has anyone run a tire this big or are these too tall?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 9:06pm
i would like to see some 16.9 on a wd 45 also, and a d17 before i buy the next set of 14.9s
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 9:11pm
been running 16.9's on wd45 for a lot of years' works good for tractor rides also. more ground speed also if needed.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 9:26pm
You can put 16.9s on, but you would need to use wider rims to go with them.  Mounting them on the standard size rims, the entire tread pattern will not properly contact the ground - only the center of the tread will.   You need the wider rim to get the full tread pattern on the ground.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 2:20am
Regarding rim width. They are suppose to be on 14 - 15 wide rims. I have my D 17, 16.9 tires on 13" wide rims and they work really well at 14 lb, pressure with 400 lb, per wheel weights. I also put 16.9's on my 850 Ford, with 13" rims. I have 700 lb, per side weights on it and run it at 12 lb and it works fantastic.
I've seen 16.9's on 12" rims and I think you could get by with it, especially if you can run lower pressures. My D 14, came to me with both 14.9 & 16.9 x 26 tires, both sets on 12" rims but, I haven't run it yet, it has a bad engine but, it doesn't look out of place.
Edited by frnkeore - 08 May 2020 at 2:25am
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 8:23am
Here is my D17 with 16.9's.
Here is the WD45 with 14.9's
WZ getting 14.9's
Here is a rear end shot:
The 16.9's would work fine, but as mentioned you may need to be at a 14 or 15 inch wide rim.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 8:28am
I have 14.9 x 28 firestone on mine on new 13" replacement rims. Looks good. 16.9 may work okay as well. Probably have to run those with rims adjusted out a bit or they will be into the fenders.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:00am
16.9's on my 17
Charlie
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:03am
16.9's on my D17.  Anything smaller is too small IMO
D17 Series 1
Allis B- 1939
Allis B- 1945
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:17am
A lot of tires say on the sidewall mount only on 15 inch wide rims
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:57am
Thousands of D-17 tractors had 16.9 x 28's on 13 inch rims from the factory.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 10:58am
My father has them on his 45 with 13” rims. Depends on tractor use, will no longer pull 3 16” plows in 3rd gear at all. Depending on ground conditions, 2nd is a struggle. Nice size for raking hay though in 3rd. I have 14.9 on mine and wish I went to the bigger ones.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 11:02am
Nick, I have Firestone 16.9 28son my WC also had them on my D17, until I found sone Firestone 18.4 x26's froma gleaner C11 already to go,on 8 bolt wheels. Bigger is good when pulling I could go over the holes guys pulling 13.6 and14.9's left behind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 3:13pm
This is my D14 with 16.9 x 26 tires on 12" rims and a picture of my 850 with 16.9 x 28 tires, with 525 lb outside weights and 220 lb insides, @ 12 lb.
Edited by frnkeore - 08 May 2020 at 3:14pm
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 3:49pm
Frank,
You have a 16.9 problem!:) I like the look! That Ford has a lot of rubber on it!
Those pie weights look good too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 4:28pm
LOL Thanks Chris. It's the one I placed 2nd with in last years pull but, with 14.9's and the small (30 lb, 450 lb per side) weights and no enter weights. No pulls this year though :(
Those pie weights, were a LOT of work!! I had to first sand blast the extremely rusted  mounting plates (I hate sand blasting) and clean up everything else on them.
Mounted the inside weights and tires on the tractor, then the pie weights. 45 lb each, doesn't sound like a lot but, there are 24 of them and they barely fit, inside the rims. I painted everything up good, hoping I never have to do it again.
All worth it after it was done though :)
Frank
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 10:10pm
i think that i will watch for a used set of 16.9s and mount them up first before i buy new ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 10:26pm
 Ive been doing that for several years, no luck so far, within a reasonable distance   for travel anyway.Ouch
MDWilliams338 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MDWilliams338 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 12:27am
Don’t stop at 16’s ...bigger is better right? 18’s on my D17 gave it a big case of the fat butt.😁But 16’s are great on a 45 although currently I have 14’s on ours mainly because the tires were too good to swap out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 11:36am
As you might have guessed, I'm a big tire guy but, even though I have a set of 18.4 x 26, on Gleaner rims. I can't install them, until I get a wider trailer. 16.9's, on a 17, won't fit on a 6 ft wide trailer. I had to take the 1.5" rails, off the back of mine, to get it to load and it rubs the sides of the fenders that way.
A quick little story : When I took my D17 to the pull, last year, I found that it would fit, w/o the rails. It's a 10K, heavy trailer and the deck is exactly 75" wide w/o the rails. I drove it on with about 20 lb of pressure in the tires and had about 1/8 - 1/4" per side clearance. At the pull I lowered the pressure to 14 lb and after loading up, the tires were pushing on both fenders.
I need a different trailer but, they cost more than most D17's Cry
Frank
