16.1” farm wagon rim ID?? |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Topic: 16.1” farm wagon rim ID??Posted: 25 Mar 2022 at 5:24pm |
Just bought three 8 lug farm wagon rims at a farm auction. One is stamped 15x10. Another is stamped 16x10. Last one is not stamped anywhere. In comparison, last one is just a little wider than the 16x10, but same/very close on diameter. Wondering whether the un-stamped rim might be 16.1? Anyone know differences & if so please advise how/what I need to ID a 16.1 rim. - thanks
Edited by AC7060IL - 25 Mar 2022 at 5:25pm |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 25 Mar 2022 at 5:49pm |
I'm shaking my head THINKING that some fool MADE a 16.1" rim !! curious was I ...googled.. OUCH, yeesh, WTH.... from another site.. Had them on a Claas baler, and no it does not work. You have to buy the right tires and their usually expensive. Millertire has 2 rims !!! sorry but it's just WRONG to me....
Edited by jaybmiller - 25 Mar 2022 at 5:52pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 25 Mar 2022 at 7:30pm |
LCG tractors of all different colors had 18.4X16.1 rears with 8 bolt centers.
Joined: 11 Sep 2009 Location: illinois Points: 90873 |
Posted: 25 Mar 2022 at 7:58pm |
I guess im lost... The FIRST rim is 15 x 10... 15 inch ID tire and rim is 10 inches wide-- Is that the OUTSIDE WIDTH, or side to side where the BEAD sets ?
Second rim is 16 inch DIAMETER and 10 inches wide, so takes a 16 inch ID tire... again 10 inchs WIDE is pretty wide.. Is that total or WHERE THE BEAD SETS ? Third rim is 16 inches DIAMETER so takes a 16 inch TIRE.. but is a little WIDER than the 10 inch WIDE rim..... Still takes a 16 inch TIRE... where does the 16.1 come in ? These are basically wagon or truck type tires... 15 or 16 inch ID and about 32 inch OD tires ???
Posted: 25 Mar 2022 at 8:03pm |
you want ACTUAL reading, not OVERALL........
Posted: 25 Mar 2022 at 8:14pm |
looks something like this... if the THIRD rim is just 1/8 inch wider or so... then its still a 16 x 10.
bigal121892
Posted: 25 Mar 2022 at 8:41pm |
We had 18.4X16.1 tires on our silage wagons.
Jim.ME
Posted: 25 Mar 2022 at 8:48pm |
!4" wide x16.1 diameter, 8 hole rims. One source, web search shows others.
plummerscarin
Posted: 26 Mar 2022 at 10:33am |
I checked a wheel off my wagon with 14L 16.1s on it. Could not find a size stamped in it other than what appears to be a date code. Best advice I can offer is measure around the rim with a seamstress tape where the tire seats on the bead. If my math is correct:
16.1 is 50.554 inches around 16 is 50.24 inches around |
Posted: 26 Mar 2022 at 1:04pm |
he said the rim is "about" 10 inches wide... Do they even make the 16.1 DIA rim in a 10 inch width ? I see 14" and bigger... Not sure i have seen a 10" ??
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 27 Mar 2022 at 11:44pm |
Me thinks buying another rim or so and going to 16 or 16.5 and using those tires as can find easily in wider tires .
AC7060IL
Posted: 28 Mar 2022 at 6:46am |
The 16x10’s bead measures 50.25” & it’s inside bead width is 10”. I have different gravity wagons that use all 3 rims. Most AC 7000 & 2wd 8000 series tractors have 16.1 front steer tires(14-16.1,18.4-16.1, etc). |
