140 wt gear oil
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: 140 wt gear oil
    Posted: 02 Jun 2011 at 4:43pm
Manual calls for 140 wt oil in the front pedestal on WD. That weight is no longer available, what weight is comparable?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 7:00pm
It is available everwhere.
You will probably find it to be a 85w-140 synthetic gear oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 7:06pm
Here is a link for a straight 140 if that helps you if you can't find it in your stores.
http://www.unifireusa.com/retail1/item.php?vn=73742&nameIT=1%20Qt%20140%20Weight%20%20Multi-Purpose%20GL-4%20Gear%20Oil&blkNO=2027-8230
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 7:12pm
NAPA also sells a straight SAE 140w gear oil.
Part Number: SL SL24228
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 7:30pm
Ok, I will try some other stores. Thanks for the info.
