138 CI engine
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: 138 CI engine
    Posted: 21 Jun 2017 at 9:19am
Found a 138 cu in power unit. What other Allis equipment used this engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2017 at 11:59am
The  138 was designed after the 125 ( B- C- CA) and was used in the D10-12 tractors. You can put the 138 in place of the older 125 ..... might be a tad underpowered for a D14, but would work.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2017 at 8:43pm
138 engines were just used in the early non live PTO D-10/12 tractors besides power plants etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2017 at 9:01pm
Thinking of putting it in a CA. The breather tube would need to be moved.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 6:51am
One can put the 149 Piston/Sleeves in the 138 to make it a 149. If memory is right, the crank, cams, and heads are interchangeable. The 138 is 5-10 more HP than the 125. Don"t know what other mods are needed to drop the 138/149 into the CA; however, would expect some as the 138/149 were used in the next generation after the B/C/CA tractors (the D10/D12/D14/D15). Sounds like a fun project and should make the CA more lively.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 7:50pm
Started the 138 today and it runs nice. Looks like the radiator will need a new hole on top and the valve cover will need a new hole in the center to work in a CA
Radiator hole......Boooooo
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 9:13pm
Can you just change valve covers?
  Got a D14 engine  parts/block head...  and was wondering if its possible to drop the engine into an RC and build it to 40-50 hp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 6:10am
We put a complete 138 head on a D-14 149 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 6:14am
Lon:For the top radiator hose, just get the top hose fro a D10/12 tractor. No need to do anything for the radiator. Although you'll need to find a place to mount a temperature gauge.
JC: The 138/149 can use an overhaul kit that will bring it up to 155 and will have higher compression. That along with some cam work head porting and a larger carburetor will get you into the 40-50 HP range. However I have gotten a BE/CE block much larger than that and making about 75 HP.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 6:56am
What is different in a b and c engine from a  ca other than gov spring.Restored a 49 b and put a ca carb on and had  to file out holes to get it on .Cranks runs and pulls good but surges at high  no load. Have adj gov rod. Seems to be a little rich.Wonder about intake and venture in carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 7:09pm
Looks like a D14 upper hose will work if I trim it. I have not solved the valve cove issue yet. Had hoped that a B valve cover would work, but not the case. Looks like a new hole will be made in the valve cover. The temp gauge is another problem.
I cut the grass today with the CA and will do the engine change out tomorrow. Should be fun.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 10:05am
I put a D14 149 engine in my lowered B for mowing. These are some of the things I needed to do. The 138 eng. should be all the same.
Had to use the B fan, and the B flywheel and clutch. The D14 manifold required moving the muffler hole a little bit. The B air filter will not fit with the D 14 manifold so I fabbed a new tube and used a K&N filter, and moved the hole in the hood. Made a instrument box mounted on the steering column for the temp and oil pres. Needed to drill out the holes in the radiator mount to the engine to 5/8". I made a patch to cover the B temp gauge hole and oil cap hole. I also added the fuel gauge mount from the D14 tank, of coarse not necessary.
That's all I can remember, it all worked out well, have fun.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 6:45pm
Got the 138 in the tractor today. Have to work on a broken bolt that holds the coil on. The choke linkage is broke. Needed to build an adapter plate for the air cleaner. Oil gauge is in the same place. Think I will build a bracket for the temp gauge and mount it in the same hole. Needs a thermostat. Was a neat project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 8:31am
Lon, I only moved the oil pressure because of the mower lift cylinder was in the way.
We would love to see pictures.Smile
Bill B
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 10:38am
I never cease to be amazed at the "designer things" you do to the tractors I sold.
At a tractor pull I saw a CA with a D-14 engine.  Worked fine and pulled very well.
Good Luck!
Bill Long
