12x24 rims
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 12x24 rims
    Posted: 26 Jul 2022 at 11:44am
My D12 rims are beyond repair (4 rail 10x24) and I have been looking for used ones and haven't found any.
My tires are bad also so I purchased a nearly new set of 13.6x24 tires. These should go on 12x24 but will they fit on a 10x24 without bulging in the middle?
Miller Tire has new 12x24 4 rail for $569. Good price?
Otherwise I was thinking of a blank rim ($160) and using my Wheel and welding on adapters for the offset I want. I don't really have a need for power adjust but I don't want a cheesy looking setup either.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 12:40pm
Charlie, would it be possible to use a 4 LOOP  , or modify a 6 loop to fit a D12 ? ... I know the 4 loops will fit the older B and C tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 12:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 1:10pm
I thought of the 4 hoop but couldn't find a 12x24 one.
That was one of my thoughts of using a 10x24 rim if it would work.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 1:13pm
All State has the 6 loop rim... Cut off 4 of them, the other two will be OK... reinstall 2 of the 4 that were removed ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 1:35pm
Do you know if someone makes the loops as a separate item? Then I could use a blank rim and install them as needed
Charlie
lockheedt33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lockheedt33 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 2:22pm
I’ve dealt with Wold Rim and Wheel in St Ansgar, IA for loop rims for the C. They manufacturer new rims as well as do all kinds of rim modifications and repairs. They may be able to weld your rails into new blank rims if they don’t make what you need as a stock item.
1941 AC B
1948 AC C
1951 AC CA
1954 AC WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 5:26pm
Thanks, I will check in with them
Charlie
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 8:06pm
I purchased 12 x24 spin-out new rims 12 years ago to include shipping for$522.
And mounted like new Firestone  13.6 x24 tires. These worked very good for my tractor pulling with my 57 model CA. I have not seen any 13.6 tires on a 10” rim. You will end up with a overall diameter at about 48.5”
If you have a Farmal A orB center along with the 4 loop 12” rim, would that work for you?
That would keep you at a 47.5” overall diameter!
Let us see your finished setup!
DeWayne
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2022 at 10:12pm
ag wheel express will custom build most anything you want for a very reasonable price.  Good guys to deal with.
