12-volt regulator |
Mark G.
Joined: 05 Mar 2012 Location: Sussexcounty NJ Points: 30 |
Topic: 12-volt regulatorPosted: 05 Mar 2012 at 8:23am |
I have a 1956 Allis Chalmers WD45. does anyone know if you need a regulator and solenoid for a 12 volt system? When i got my tractor it did not run, and the wiring was converted from 6 to 12 volt, and it did not have either of them. |
CTuckerNWIL
Posted: 05 Mar 2012 at 8:32am |
You don't need a regulator if you have an internal regulated alternator. You don't need a solenoid if you use the original starter and pull switch.
Mark G.
Posted: 05 Mar 2012 at 8:36am |
Thanks for your help.
Mark G.
Posted: 05 Mar 2012 at 8:45am |
CTuckerNWIL
Posted: 05 Mar 2012 at 10:19am |
Looks like you have the start of a nice snow plow rig or a light dozer there. Might need to store the hand crank though.
Mark G.
Posted: 05 Mar 2012 at 10:46am |
Yep, thats a plow frame on it. The hand crank has been removed. that pic is when i got it so the hand crank is rusted on. I removed it by spraying on a little pb-blaster.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 05 Mar 2012 at 10:53am |
I converted my 56 WD45 to 12volt using a generator (working one was FREE) and bought a D17 voltage regulator. I drilled holes in the front of my battery box and mounted it there. Works great for me. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Mark G.
Posted: 05 Mar 2012 at 10:58am |
I have a brand new 6-volt generator i was going to use on it, but you get better cranking in cold weather with 12-volts. going to sell my 6-volt. |
Skyhighballoon(MO)
Posted: 05 Mar 2012 at 11:09am |
Here's some pics of my 12v conversion. I went generator instead of alternator not only because of having the generator free but also because the 190 picker is going this tractor and an alternator would stick out and not allow mounting of the left engine side shield. Mike
Mark G.
Posted: 05 Mar 2012 at 11:14am |
Very nice setup. I might have to try somthing like that because I have a regulator from a D-17. I would only need to get the generator then. |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 05 Mar 2012 at 9:30pm |
Hey Mark G! Are you the same Mark with the Model B over on Sid Taylor Rd?
Steve@B&B |
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 05 Mar 2012 at 10:19pm |
I have a remanufactured generator that I got from Value-bilt a while back for my D15, but it was too log to fit in front of the carb. Will work fine on the larger WD engine. I'm in Eastern Pa, near Easton. Bob
Mark G.
Posted: 06 Mar 2012 at 7:18am |
Hey Steve, no Im not the one on sid taylor road(I know were that is though), I live over in stillwater. (wish I had a model B). Edited by Mark G. - 06 Mar 2012 at 7:22am |
Steve in NJ
Posted: 06 Mar 2012 at 7:47am |
Oh okay. Different Mark. Mark over on Sid Taylor is a nice fella. He's bought some parts from us for his B model. Thought maybe he bought a 45'. Orange is addicting!
Mark G.
Posted: 06 Mar 2012 at 8:03am |
Hey Steve, thanks. I was originaly just going to get my wd45 so it ran and I could use it but I changed my mind and am going to restore it completley. So if I'm stuck on sumthin I'll be sure to ask. Thanks again.
