125 cu. in. serial #...
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: 125 cu. in. serial #...
    Posted: 02 Feb 2017 at 1:50pm
Just wondering what details are in the serial # of my 125 cu. in. A-C. The stamped # is CE 87289 G. I figure the G is for gasoline  but CE??  Any info is appreciated - thank you!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 2:00pm
CE is just the newer model of engine line that the Bs,Cs, and CAs came out with. Before them was the BE engines. CE engines had a larger bore than the BE engines.
Edited by AJ - 02 Feb 2017 at 2:01pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 2:27pm
and the year of manufacture is approx. 1948.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 3:02pm
CE = 125 CID.  BE = 116 CID
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 4:57pm
Thanks for the enlightenment, as Steve said 1948 ...it is in my '48 B. Because it has distributor ignition I had wondered if the engine was newer than '48. Obviously someone has switched it from mag ignition along the way as that was not available in that year.
