12 volt coil
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: 12 volt coil
    Posted: 03 Dec 2009 at 9:02am
I'm trying to scrounge up a 12V coil for a C with a Batt ignition. I can only find free coils that say " for use with external resistor". Will they work without a resistor? Is the resistor the condensor looking thing with one wire right at the coil on a Dodge? If I have to use it, what pole does the resistor wire connect to?  I'm  presumeing The 6 volt coil has to be changed when converting to a 12 volt system .
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 9:07am
Ken,
I bought a simple generic 12 volt coil at Farm and Fleet for about $12. It was in the automotive section. It didn't need a resistor and it works great on my WD. Never had a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 12:49pm
Before I converted my CA to electronic ignition, I had a coil from a Kohler K301 engine on it. The Kohler coil didn't use a ballast resistor on the single cyl engine and I never did on the CA either. Worked just fine.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 1:29pm
The will work without a resistor, for a while. But they will burn the points from too much current and will eventually fail from too much current in the coil. You need the ballast resistor with resistance about the same as the low voltage winding of the coil to use those coils on 12 volts.
Most any vehicular coil without a resistor (most likely a 60s or earlier vintage Ford coil will do, providing its later than about 1955 to avoid being 6 volts or later to avoid being solid state ignition) will do just fine.
NAPA is reputed to have a suitable 12 volt coil needing no resistor for maybe $15.
Gerald J.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 5:37pm
Ken I have used several NAPA coils with no problems, ask for one that says 12 volt no external resistor required. Mark L
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 5:45pm
Most GM coils from 1955 on and many Chrysler coils also used a external resistor to drop coil voltage to around 8V. GM did away with the external resistor by using a resistor wire from the ign switch in later years.
 For starting the coil picked up voltage from the starter lug on solonoid of Delco starter which was 12V when key was turned to start. When engine started the wire from ign to coil was run through resistor to increase point life.
 As far as wire , either end as resistor is not polarity sensitive, but points and coil are as they need to be same polarity to ground as the battery is. So marking on the coil to ground should be same as battery.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 6:53pm
If you just want to "tinker" with all your used parts, the DC current through the coil and points with the engine shut off should be approximately 3 Amps (it will be less when the engine is running). This will prevent overloading the ignition system and preserve the life of the points and coil. You can sort through ballast resistors and coils until you find a combination that gives the above values.  If you just want to get the job done and move on, go to an auto parts store and buy a coil that is labeled "12V, no external resistor required".
Why is there never time to do it right the first time, but always time to go back and fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:46pm
When running a 12V conversion with a 4 cylinder engine, you need 2.7-3.3 ohms of resistance in the Ignition circuit for the engine to run correctly and not burn up the points. Stay away from external ballast resistors. They didn't work under the hood of 60's auto's, they sure as Hell ain't gonna last to long hanging off the side of a tractor out in the elements. Mother nature plays havoc with those things. We offer a 3.0 ohm coil with built-in resistor. You can also purchase one from Napa or your local auto parts store. Just tell them you want a 3.0 ohm coil with built-in resistor. Your done.....
Steve@B&B
This page was generated in 0.088 seconds.
