12 row 7200 finger pickup on 7030
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 12 row 7200 finger pickup on 7030
    Posted: 07 Mar 2026 at 8:27am
New to me this year is a 12 row 7200 finger pickup planter. The PO ran it with a deere and mentioned setting the return hydraulics for lowering planter to case drain, his tractor wasnt setup up that way but mentioned it would be faster to lower and go. Any experience with this?
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 8:28am
Plan to pull planter with my 7030, Or my 7580. Not sure yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 8:53am
A finger pickup planter only requires hydraulics for up/down and the markers. Plug both hoses (or 4 hoses) into your tractor like usual. Make sure your hyd levers and cable linkage parts are all allowing full stroke on the spools. Might adjust flow rate speed under the seat. DON'T use any in-between adapters from a Deere Hyd hose end to fit an A-C tractor. Change the tips on the ends of the hoses to mate directly with A-C couplers.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 10:05am
X2 with DrAllis comments. The mechanical 7200 should be a good planter combo with most ANY tractor.
If PO has not had finger pickup meters professionally tested at Precision Planting, get them boxed up & shipped to Tremont IL (if they still do them?) or deliver them to your local Precision rep for testing, rebuilding, & calibration.
Try to mix a talc/graphite lubricant powder mixed into seed. It doesn’t take a lot(1-2oz per hopper). Fingers, springs, ash-trays etc will thank you for lubricant. Singulation belts get brittle with age, so change them every testing. Too much talc/graphite & the seed tube monitors may get overly dusted & then prompt no seed. Buy a seed tube brush for occasional tube cleaning. Brush can usually be stored away inside one of the insecticide boxes.
Edited by AC7060IL - 07 Mar 2026 at 10:11am
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 10:19am
and if you want precision stay under 3.5mph and fingers do just fine
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 1:48pm
The planters I am used to were all three point, and what I remember is a single hose for the markers, so assuming you have either lift assist or a pull type planter. If it has double acting cylinders to raise and lower plumbing the return to the case drain would actually slow it down. The oil that you are returning is the same oil you pushed out through the valve under pressure to lift it, and having pressure push it back would help. I think the previous owner may have heard about going back to the case drain to help with hydraulic heat issues on the vacuum planters, particularly if you pulled it with a green tractor.
The finger unit is a good unit that had a lot of aftermarket available. Where I worked we did a lot of sweet corn that didn't always have good seed shape so we would usually replace the brushes twice a year, sometimes three times depending on seed to keep from getting doubles. I also worked on one that was never used for sweet corn and didn't see near as many acres, used the Precision brushes in that one. If I remember right they are adjustable. Precision has youtube videos showing their products and some of the common issues if you aren't familiar with that unit.
Ted
Edited by TedN - 07 Mar 2026 at 1:50pm
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 2:51pm
My 7000 finger pick properly maintained depending on seed size will plant on the nose up to 5.5 mph. ground conditions, chain and sprocket condition will make a world of difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 2:53pm
Also make sure the master cylinder is phased with the slave cylinders. The operators manual will explain how to phase the master cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 3:03pm
Medium round seed gives best results for spacing and singulation.
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2026 at 7:35pm
Agree with Dr. Allis.  We run 2 Kinze finger pick-up planters.  6 row on a 185, 15r/15" on a 210.  4 hoses.  When we have the remotes dialed in, it's pick-up and drop and back to detent. Just simple and works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 6:14am
You guys speak of 4 hoses. This planter runs off of 2 hydraulic hoses to valve body with electric solenoids to operate planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 6:26am
Same system. It is 4 hoses beyond your electric valve.
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 9:51am
Hey bleeds orange sounds like that planter is set up for closed center hydraulics where you leave the remote in constant detent
To use it on an Allis chalmers you would have to hold your remote then work your toggle switches for the markers and up and down if I understand what you have
There is a way to make it work by adjusting a screw in the valve body of the tractor Dr Allis could explain it better than I could
Have done it on an 8070 to run a John Deere forage harvester but that’s been a few years
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 9:06am
what population you running? the more the slower driving required according to book. I plant 32400 book setting and seems very close. 12 row Kinze. Pretty sure I drive too fst but have no high tech on my 8030 planting tractor to tell me.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 10:50am
hopefully by now you have an owners manual. lotsa info in one of those.
planting speed will depend on your desired population, higher pop's require slower speeds. ground speed has a direct correlation to the finger pick-up speed, and the finger pick-up works best at a given RPM, ie,, lower pop's, its turning slower,, so ground speed can be increased,, higher pop's, it has to turn faster,, so, slower ground speeds..
the hydraulics,, well,, I'd hook them up as normal,, 2 hoses, to 1 remote, if there is another set of hoses, , hook to another remote.
If there is only 1 hose to an operation,, hook to the hose to whatever side of the remote on the tractor works best at for a single acting cylinder
