12 Cylinders and twin turbos hard at work
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 12 Cylinders and twin turbos hard at work
    Posted: 13 May 2020 at 10:27pm
Just not in one unit!  Finally had a decent day for some open air cultivating.  The 190XT running a paltry 15' International Vibrashank.  The D21 is mated to a 1300 silent weed killer that measures out at 27' at the widest point!  It didn't look that big with the wings folded up.  Sink it in the ground too deep and the D21 stops in its tracks.  I didn't put fluid in when I put new tires on the back.  Second guessing that decision now...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 6:56am
Don't sink them in too deep, you may bend the shanks. BTDT. I don't know your operation but I don't need to dig deep. I chisel first and only use the 1200 as a final pass to incorporate fertilizer and pre emerge 2 or 3 inches deep.
Wink
I am a Russian Bot
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 7:44am
Great orange field photo’s - thanks for sharing. If possible, try reducing your AC 1300’s shovel size down to 4” (10cm) width. For convenience, try adding 1or2 300lb rear wheel hub outer cast donut weights to each side of your D21, instead of adding fluid.
Is your XT a series II? Is it’s rear tires 38”? Wish mine looked that great - someday...
Edited by AC7060IL - 14 May 2020 at 7:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 9:27am
The shovels are very worn, so probably didn't make it easier to pull.  I definitely do not want to add fluid to the rears, so maybe if I get lucky I can find a set of weights cheap!
The 190 is a 1967 Series I with 18.4 x 34 BKT rears.  Finished a very expensive restoration 2 years ago, but it's good to put it to work when you can.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 2:34pm
Nice looking outfits.  Lonn's right about not too deep with that field cultivator.  3" normal, 4" at a maximum.  Just deep enough to get a smooth, level surface.
I'll bet they're fun to run.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 2:38pm
Or beet juice, although that aint cheap either
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 5:49pm
Field cultivators and their Owners are funny. I had two Customers with 7040 tractors that were pretty much identical in tires/duals/weight and HP. One bragged about pulling a 26 ft field cultivator at 5+ MPH and the other thought 20 ft was plenty most of the time. What a difference one inch of depth can make and the width of the sweep !!!!
Edited by DrAllis - 15 May 2020 at 5:50pm
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 5:18am
Love your post caption D series4, everybody and their Uncles are going to click on that baby.....and your pics are great too!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 7:11pm
Great pictures!  Wish I could enjoy a couple passes of seat time on one'a those!
I remember my Grandfather interjecting into two younger farmers' bragging duel about their cultivator rigs.  He said something to the effect of:
"Silly to argue about it- I worked both your daddys' fields long before you were born.  You got a riverbottom field that is all sandy loam, I've been through it with a huge cultivator like butter on my small tractor... and HIS is a clay hillside, can't cut through it with half the steel and twice the tractor..."
This page was generated in 0.344 seconds.
