11x7 Drill on a WD45 |
DakotaSteve
Topic: 11x7 Drill on a WD45Posted: 05 Nov 2018 at 8:41pm |
I mounted my drill on the 45 today and it seems way to close for comfort on the rear tires.. .were these designed just for the WDs w smaller tires? I see some literature says CA and WD mounted drills....
dawntreader74
Posted: 05 Nov 2018 at 9:16pm |
mine mounts close also on the 45' with 13.6 tires. it's the one with the gear for the chain bolts to the tractor wheel center. thank it needs to be close. ?
DakotaSteve
Posted: 06 Nov 2018 at 5:47am |
I have 14.9s is that my problem maybe?...and they are newer tires.
dawntreader74
Posted: 06 Nov 2018 at 6:35pm |
maybe; do you have the gear on the rim that drives the drill with chain?
DakotaSteve
Posted: 06 Nov 2018 at 8:33pm |
Dawn treader yes but havent hooked it up yet.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 07 Nov 2018 at 7:50pm |
If it ain't rubbing,go with it!
dawntreader74
Posted: 08 Nov 2018 at 12:10am |
like steve said;; if it's not rubbing or hitting any thing i would hook it up an use it.
