#118254 Lives On
drivere350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivere350 Quote  Post ReplyReply Direct Link To This Post Topic: #118254 Lives On
    Posted: 11 Jun 2010 at 10:32pm
1950 WD, a bit rough around the edges. I plan on keeping in running to help clean up around here and maybe do some restoration in the futures. Came with a modified bucket and new tire chains. Runs really good so I'm happy. I'm the 3rd owner and my first real tractor.
Edited by drivere350 - 11 Jun 2010 at 10:36pm
Francis/Northern MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Francis/Northern MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 6:30am
Nice WD.  It's a 1952 by the serial number you posted.  I have a '52 WD serial # 122490 with a Freeman loader on it.  You'll find lots of uses for that WD and loader.  Enjoy your new tractor!
Francis
Bemidji, MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 7:05am
I will bet that extra cylinder makes it a lot handier than a regular trip bucket. Is that plumbed in to the WD hydraulic pump. I can't tell from the picture to, but don't see a secondary pump anywhere. Nice outfit.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 7:31am
I was also wondering what your pump setup was.
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 8:17am
i noticed that there is 3 levers... whats the 3rd lever for?
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivere350 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 9:52am
It's running off the original pump so there isn't down pressure on the bucket and it's a bit slow. It is useful that the bucket can be held at a down angle, unfortunately it only angles up a couple degrees so it's not a real digger.
The levers control lift, bucket, and 3 point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivere350 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 11:40am
Here's a walk around with some hydraulics.
http://video.yahoo.com/watch/7646328/20312271
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2010 at 11:49am
Nice, thanks for sharing!  It's nice to see more WI guys here.  I'm originally from Ashland WI.  I see you're from around Eagle River.  We've been to the tractor show there one summer a few summers back.   And I got my 1949 C "Frank" from that neck of the woods too.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
