11000 rebuild
Joebell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joebell Quote  Post ReplyReply Direct Link To This Post Topic: 11000 rebuild
    Posted: 06 Apr 2025 at 10:08pm
Was wondering if anyone knew where I could locate a rebuild kit for the 11000 series allis motor it’s in a 73 hd 11-B thanks for the info!
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 6:36am
This is not an easy engine to find rebuild kits for unfortunately. Olson's Gaskets can make a set for you but the $$$ add up quickly. Arias Pistons can make a set of pistons, and rings can still be sourced through them but again, the  $$$ add up quickly. I have an extra set of bearings, but found them through a fellow formerly worked with and I don't know where you'd get a set these days.
It would take some workarounds, but you could install a Cummins in the tractor probably easier; although still a lot of work. The tractor would need to be in very good shape to justify this however.
That's All Folks!
