100 Series Disc Question
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Topic: 100 Series Disc Question
    Posted: 04 Jun 2017 at 11:49pm
Will an 8' 100 series Allis disc work on a CA or WD....looks to be nearly the same as a model 20....?
boggen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boggen Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 3:55am
not sure what model i have for the CA. i want to say 6 foot length.  approx 1 foot width on each side of rear tires (rear tires set to max width).  and it is all the CA can do to pickup the entire disc. and even then one of the rear end discs wants to drag just a tiny bit if you hit a bump or like.
i gotta be careful coming out of a freshly plowed area and disc still some what in ground. or the front wheels will come off the ground on the CA.  and that is with the side weights up on the front engine. (no direct weights out on the very front)
pulling the disc is no problem. it is just lifting it up, so you can actually turn that is the issue.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2017 at 8:05am
Yes, it should work but I'm sure the front end of the CA will need more weight.  I've got this #109 that I pull with my WD-45.  I've got front wheel weights and I still can get the front end in the air if I get too aggressive (aka stupid) if I take off too fast with the disc raised.
