100 Series 7'th gear ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: 100 Series 7'th gear ??Posted: 04 Jun 2020 at 7:29pm |
Was there a "field" use for the 7'th gear; 4'th gear/low range ?? Now that I think about it, how about the D series
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 04 Jun 2020 at 7:32pm |
10+ Mph in the field? I've never done that! 4th Gear in general is more of a road gear be it high or low range to me.
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 04 Jun 2020 at 7:38pm |
At about 1/2 throttle, or 5MPH I used to rake hay to initially turn it over to dry better. I did wish for a 5 speed many times for more speed selections.
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
FREEDGUY
Posted: 04 Jun 2020 at 7:50pm |
I just assumed that there was a reason for that particular "gear" LOL !! I can understand the 8'th/road gear though, perhaps 7'th was easier on the driveline to get there ?? What about rotary hoe work ?? I've been told that the "faster-the better" ??
Edited by FREEDGUY - 04 Jun 2020 at 7:52pm |
Stan R
Posted: 04 Jun 2020 at 8:07pm |
Spent most of today on a D17, 4th gear low range raking.....maybe 1/4 throttle. 3rd gear hi, full throttle, as the field got "smaller"
Edited by Stan R - 04 Jun 2020 at 8:11pm |
orange200
Joined: 30 Jun 2015 Location: New Hampton IA Points: 53 |
Posted: 04 Jun 2020 at 8:45pm |
We used to pull a 4-section drag cart in 4th low with the D17.
MACK
Posted: 04 Jun 2020 at 8:57pm |
About right for a rotary hoe. MACK
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8684 |
Posted: 04 Jun 2020 at 10:55pm |
I doubt the engineers had 4th in mind when they came up with the concept of 2 speeds in one gear. It was for more selection in "field gears". Fourth just benefited as a tag along.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8735 |
Posted: 05 Jun 2020 at 6:04am |
When I "hit the road" with my XT, I have never, ever, took off in fourth gear high range (aka,8th gear). I'll always get rolling in 7th gear, then put the PD ahead for 8th gear. Seems a little easier on everything, especially if you have much of anything behind you. So, with that being said, in my mind, 7th gear has a purpose. Darrel
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3101 |
Posted: 05 Jun 2020 at 6:05am |
On a D series 4th low is just right for carrying hay bales around in the field or when pulling loads on hills up and down on the road it was handy to shift to low range.On the 100 series the ratio between high and low was too close not nearly as useful.
Lonn
Posted: 05 Jun 2020 at 7:12am |
Dad used to round bale at lower throttle speed in 4th low with his XT. We used to rake in 4th low with the D17 and for starting a load on the road, 4th low worked better than starting in high. I agree with Darrel, 4th low had a purpose and it worked good.
Wink I am a Russian Bot |
