1 Belt 2 tractor thrashing |
Darrell G (MN)
Joined: 11 Sep 2009 Location: Green Isle MN Points: 1496 |
Topic: 1 Belt 2 tractor thrashingPosted: 14 Jan 2018 at 4:16pm |
If you have never seen this set up over on Facebook on the Upper Midwest a-c club post is a picture of it running last July at the Orange Spectacular, it was built by Gary Agrimson and Gilbert Vust using pictures as a guide.
Darrell G (MN)
Posted: 16 Jan 2018 at 12:05am |
I am wondering if anyone seen this last year at the show, and so what where your thoughts
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5905 |
Posted: 16 Jan 2018 at 5:25am |
B26240
Posted: 16 Jan 2018 at 6:31am |
Yes Darrell I saw it and looked close at it, Gary is a master machinest which I already knew since I have been to his machine shop in the cities. For those who may not know Gary has done detailed work for the medical industry. He showed me a machine he has that can "jet" a hole thru steel just a few thousands of a inch in diameter, much smaller than can be drilled. Best of all he is a first class guy!!
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24774 |
Posted: 16 Jan 2018 at 6:45am |
I'd think they'd 'fight' each other unless the PTO speeds were exactly the same ?
Darrell G (MN)
Posted: 16 Jan 2018 at 7:33am |
Jay the key to get them to run smooth was matching up the rpms as close as possible and getting the govenors to work together
BenGiBoy
Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
Posted: 16 Jan 2018 at 8:25am |
I bet that was tricky!
What happens if they are out of sync? -Ben
'39 Model B
Tractors are cheaper than girls, remember that! |
Gerald J.
Posted: 16 Jan 2018 at 10:03am |
The slower one out of sync starts contributing only load being shoved by the faster tractor and then the whole thing slows from the fast one being more overloaded by that shoving and the threshing machine load. Probably leads to speeds oscillating down and up.
I liked the Waukesha WC at Hutch a few years ago running the threshing machine, no complication and it ran smooth. Gerald J. |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 16 Jan 2018 at 10:24am |
My grand-dad used to run a 26"-er with a F-20 and a Ford-son the same way way and he never had trouble. The higher RPM tractor cared the load in tell the slower tractor started to pull. He used them that way for years because that's all he had to work with.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Posted: 16 Jan 2018 at 11:32am |
Gary is great. Didn’t know that about his shop, though. He’s very humble. When I asked him what all he did in his shop, he said, “Oh not much, just little stuff.” I guess making a hole a couple thousands wide really IS “little stuff”. Lol |
