Zip System |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36741 |
Topic: Zip SystemPosted: 10 Dec 2022 at 5:41am |
Anyone here use the new to me home sheathing system or anything similar? Uses a green skinned sheathing and tape on the joint seams, no vapor barrier to install not sure if they even recommend adding vapor barrier.
Buddy of mine in OK has a new home going up with the system, stated even without siding or brickwork the structure with windows and doors was pretty well air tight, I was shocked at the efficiency of install and closure of his frame up. |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5325 |
Posted: 10 Dec 2022 at 5:58am |
My take on it is that it is very expensive at $33.45 per sheet verses $13.90 per sheet (both 7/16") for regular OSB right now from our local Home Depot's website.
I know it doesn't need a vapor barrier and it stands up to weather better that standard OSB, but at more than twice the price, I would think you can install a vapor barrier and cover it with siding for around the same money. it has to have siding over it eventually.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25521 |
Posted: 10 Dec 2022 at 6:06am |
New neighbour used it, regrets ever buying it and having it installed. First it's very expensive compared to 'traditional' sheathing. Their joint tape is $$$$. Second it HAS to be installed according to the instructions, even need their roller to put their $$$ tape on. If you're thinking about it, price it out and READ the PITA instructions.... from either install or energy savings ,it is NOT any better. I KNOW it's a HUGE sore spot ,regrets ever being con-vinced to using it and I NEVER bring it up.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9737 |
Posted: 10 Dec 2022 at 6:15am |
We have used it with homeowners recommendation.
Very expensive. We do use the zip tape a lot. I much prefer it to window tape. $75.00 a roll last I saw. Might be less now. I just delivered a case of it to a job this week. |
fixer1958
Posted: 10 Dec 2022 at 6:16am |
I have. The stuff is awesome. Knocked our electric bill in half.
Unbelievable for no more than what it is. The tape is the same way. Expensive but there isn't a better tape made. I bought 15 sheets pre-covid for $18-$20 each 4x8 to try it out from Lowes. Got that up and got online to order some more and it said they had 80 some sheets for $1.99 each but you had to buy all of them. Ended up getting 60 or so of them. All they had. I still have 20 or so left.
jaybmiller
Posted: 10 Dec 2022 at 6:29am |
just checked, roll of tape 6"x 90' is now $100 +13% taxes......,so over a buck a foot !!
WF owner
Posted: 10 Dec 2022 at 6:33am |
In our climate, anything I would ever build that would ever have heat source in it would be spray-foamed, which in itself is a vapor barrier, so the allure of the zip system lessens.
WF owner
Posted: 10 Dec 2022 at 6:38am |
3 3/4" x 90' roll of Zip tape is $31.68 here, so quite a bit cheaper here (but still expensive!) 3-3/4 in. x 90 ft. ZIP System Tape 5017100 (homedepot.com) |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11776 |
Posted: 10 Dec 2022 at 9:48am |
Is this one of them deal where it make the house so tight that you have to add air exchangers
DMiller
Posted: 10 Dec 2022 at 9:55am |
Could very well be!!
DougG
Posted: 10 Dec 2022 at 10:54am |
We are doing stone work on a 9.5 million $$$$ house in Clayton right now with this stuff - and they were very stern on any miss drilled hole must be covered with ZIP TAPE-
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56136 |
Posted: 10 Dec 2022 at 6:39pm |
WF owner
Posted: 11 Dec 2022 at 5:18am |
Just a thought, but if the green coating is the vapor barrier, wouldn't every nail or screw that penetrates that membrane need to be taped to have a true vapor barrier?
DMiller
Posted: 11 Dec 2022 at 5:29am |
Regular vapor barrier gets a plastic capped nail to retain and spread stress zone, builder on our house used that system, 6 of one half dozen other. Also as I read on, there is a sealant the builder is supposed to apply to nail heads much as the tape or apply tape. More I read on it the less I am sold on it now. More a Step and Time saver for builder at increase expense on materials, most builders base against sq footage in a flat rate unit price rather than a per hour as on a custom build where if building more units faster earn more cash. Another 'Trend' perhaps?
200Tom1
Posted: 11 Dec 2022 at 11:39pm |
I put it on my house when I resided it. I'd do it again in a heartbeat.
shameless dude
Posted: 12 Dec 2022 at 1:43am |
I'm seeing more and more of the ZIP systems going on new homes in my area.
