Zenith carb venturi
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Topic: Zenith carb venturi
    Posted: 16 Nov 2020 at 9:52am
On an Allis C, Zenith carb has #216937 on the outer ring of the plate, and S906 on the inner.  Venturi is trashed.  How do I figure out what venturi will fit in this?
Were the Marvel and Zenith carbs used interchangably on the B's and C's?  Does it go by year? thanks
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 12:38pm
Parts book says its part# 223808 (or 70223808) - VENTURI (size 13).  Zenith carbs 212844, 212845, & 216937 all take the same part.  Sandy Lake Implement Co. is your best bet.  Otherwise Alex09(WI) had a 212845 on hand that could be used a as a donor, if he still has it...
Can't answer the Marvel/Zenith swap question.  Only dealt with Zeniths thus far.
Ben
Edited by C in Concord - 16 Nov 2020 at 12:48pm
Leave things better than you found them.
1941 Model C (restored 2020)
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 12:40pm
I have only seen Marvels on B/C's
D10/12's I see Zeniths
Might look here:
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 12:42pm
page 4 of his Zeniths parts shows venturi's
Charlie
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 1:20pm
Might look here:
X-2! They have a lot of stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 1:47pm
The carb used on the B and C tractors could fit several different brand tractors... You change the venturi and the main jet to adjust for different displacements and rpm needed... I think the B and C tractors had a 9/16 inch bore venturi... Double check when you buy to see that you get that bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 1:49pm
There were a couple years ( during the war)  where marvel carbs were used on some B tractors... Dont know if the Zenith were not available, or if ALLIS was just pushing Zenith to keep the price down.
I have a list of carbs by year / model number... this is part of 1944...
Edited by steve(ill) - 16 Nov 2020 at 1:55pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 2:01pm
I believe your carb came off a 1947 KEROSENE tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 4:36pm
Thank you for the info, everybody.  Very interesting, especially about the possiblity of kerosene!!??  The tractor was not running when I got it, but its history indicates that it was running well with this carb.  Whether it was original, or has had jets swapped, who knows.
I will check out McDonald carb.  Looks like a good resource.
As an alternative, what # of Marvel carb should I look for if I can't fix the Zenith?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2020 at 4:51pm
my post above lists one of the Marvel Carbs used during the war..
