Z CODE ENGINE
D17-WD45-WD-WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17-WD45-WD-WC Quote  Post ReplyReply Direct Link To This Post Topic: Z CODE ENGINE
    Posted: 14 Aug 2017 at 10:15pm
In a 226 Z code, can you run a flat top piston. I've heard both yes and no. Don't want to do something to a tractor that can't be undone. Thanks
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 7:06am
Yes you can.
Best bet would be to run 175 power crater pistons as these gave great performance
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 7:25am
Z code engine is already 8.0 to 1 compression ratio. If you want more, flat tops will get you that if ( and only if) the piston pin is located correctly. Just because it's a flat top doesn't mean squat if the pin location is too high up. Any more than 8 to 1 will require higher octane fuel.
