Z CODE ENGINE |
D17-WD45-WD-WC
Joined: 14 Aug 2017 Location: Ellsworth WI Points: 6 |
Topic: Z CODE ENGINEPosted: 14 Aug 2017 at 10:15pm |
In a 226 Z code, can you run a flat top piston. I've heard both yes and no. Don't want to do something to a tractor that can't be undone. Thanks
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6372 |
Posted: 15 Aug 2017 at 7:06am |
Yes you can.
Best bet would be to run 175 power crater pistons as these gave great performance
Charlie
Posted: 16 Aug 2017 at 7:25am |
Z code engine is already 8.0 to 1 compression ratio. If you want more, flat tops will get you that if ( and only if) the piston pin is located correctly. Just because it's a flat top doesn't mean squat if the pin location is too high up. Any more than 8 to 1 will require higher octane fuel.
