wiring
 Post Reply Post Reply Page  <1 111213
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2022 at 10:44am
Originally posted by hunter321 hunter321 wrote:
ok i got every jet out but the middle tube one nothing is working on that one. can i just drill it out?
In theory you should be able to drill it out since the replacement tube will have the correct critical ID passage size. Verify depth stop (I use a small block of wood as a stop not just masking tape for critical depth stop situations).
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 9:28am
What grease do I use for the steering gear assembly
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 9:37am
i got all the jets out of the carburetor but the mount for the float broke what should i do
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 9:39am
you can solder it back together........... or buy a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 11:14am
Would I have to drill out the old pins holding it to the carburetor
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2023 at 5:08pm
The on off on switch I have has 3 terminals
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 9:44am
when i get the money i think i will take the carburetor to the tractor shop so they can fix the float bracket
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 11:54am
where can i buy the float bracket
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2023 at 11:20am
I am finally wiring up the fender lights but I can't figure out how to run the wire from the fender to the wiring box on the battery box
How were the original fender light wires ran
