wiring |
Page <1 111213 |
jvin248
Posted: 26 Oct 2022 at 10:44am |
In theory you should be able to drill it out since the replacement tube will have the correct critical ID passage size. Verify depth stop (I use a small block of wood as a stop not just masking tape for critical depth stop situations). .
hunter321
Posted: 14 Nov 2022 at 9:28am |
What grease do I use for the steering gear assembly
hunter321
Posted: 07 Feb 2023 at 9:37am |
i got all the jets out of the carburetor but the mount for the float broke what should i do
Joined: 11 Sep 2009 Location: illinois Points: 93381 |
Posted: 07 Feb 2023 at 9:39am |
you can solder it back together........... or buy a new one.
hunter321
Posted: 07 Feb 2023 at 11:14am |
Would I have to drill out the old pins holding it to the carburetor
hunter321
Posted: 08 Feb 2023 at 5:08pm |
The on off on switch I have has 3 terminals
hunter321
Posted: 15 Feb 2023 at 9:44am |
when i get the money i think i will take the carburetor to the tractor shop so they can fix the float bracket
hunter321
Posted: 15 Feb 2023 at 11:54am |
where can i buy the float bracket
hunter321
Posted: 16 Mar 2023 at 11:20am |
I am finally wiring up the fender lights but I can't figure out how to run the wire from the fender to the wiring box on the battery box
How were the original fender light wires ran |
Page <1 111213 |
