Will modern deeper oil pan clear on 220 |
NEVER green
Topic: Will modern deeper oil pan clear on 220Posted: 15 hours 16 minutes ago at 11:44am |
Will a deeper oil pan off a 7060 clear the wish bone front end on a 220?? Thanks in advance.
Posted: 13 hours 45 minutes ago at 1:15pm |
I think so. All 210's and later model 220's had the crankshaft driven oil pump on them from the factory and as far as I know, no changes to the front axle. Many old 220's that failed the camshaft driven (original) oil pump were retrofitted with a new style crankshaft driven oil pump and deeper pan as the fix. EDIT: A 210/220 crankshaft driven oil pump is p/n 74028052 The crankshaft driven oil pump for a 7030 is also 74028052.
Edited by DrAllis - 11 hours 11 minutes ago at 3:49pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9260 |
Posted: 4 hours 22 minutes ago at 10:38pm |
My 70 model 220 had 3000 ish hrs when i got it. It has a block with no serial # on the plateand has crank driven pump. I assume it was one that failed and was replaced with later stuff. Can't speak to the oil pan issue other than it has one that fits. At 5 1/2 gal it is full on stick and follows manual capacity. That's 1 qt more that my 8000's with the bypass filter and larger oil filters. That don't make sense to me.
