what model plow is this
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: what model plow is this
    Posted: 29 Sep 2026 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2026 at 10:12pm
4 bolts on the shears  three bolts in a straight line  the  the front one is alittle lower  none of the center to center on the bolts is the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2026 at 10:24pm
If the frame width can be assembled 14 or 16 inch width I'd say 70 series. Bolted only to one frame width 60 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 10:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 10:59am
does this help alittle bit dr. allis   need to find shears for this and land slides also
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 11:15am
70-series. There is more than one plow "bottom" for the 70-series. And that determines what shares or landsides. I have made my own landsides out of 1/2" or 3/4" flat steel. They won't last as many acres as OEM, but my plow days don't happen that often and new landsides sure do keep the plow straight when plowing.
Edited by DrAllis - 30 Sep 2026 at 11:18am
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 11:54am
Are the shears 3 bolt or 4 bolt, that is something you need when looking for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 7:29pm
Unbolt and look for part numbers on back side of any of the wear parts
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 5:58am
Had to dig the bible out and review my Allis plows. The good Dr. is right, a model 74 pull-type. Not a real common plow. If it had cushion trip bottoms it would be an 84. Dave the plowman probably has wear parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 6:32am
Not really a common A-C plow for sure. It would be interesting as to what tractor actually pulled it. It is set-up for a 14 inch cut, which in a mounted style would fit a D-17 in my neighborhood, but a pull type version takes more tractor to pull it. If it had been hooked to a D-19, I would have expected a 16 inch cut setting. Maybe it was pulled by a brand X tractor ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 10:29am
i think this was a 5 bottom .          some cutting has been done on the back at some time .  this one was given to me.         all i will use it for is plow days and parades  but i will replace re build the cutting parts,  just did all the wheel bearings and tires before itook it off the trailer .   going to pull it with the d17d
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 11:25am
If it was my D-17, the drawbar would be modified and up to probably 24 inches high. Good tread 16.9 x 28 tires FULL of fluid with 12+ psi. 600 lbs of rear wheel wts (300 a side). Need 300 or 400 lbs on the nose. Let the plowing begin !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 9:16pm
What model number bottom is it
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 9:57pm
still have to get one apart  to see  but the shears  are five bolts,      have brand new 28 x16,9 firestone super all traction 23s  with calcium  and one weight on each side   nothing up front  yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2026 at 11:35pm
I think we have a operators manual for  model 74
