What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 303132
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 5:34am
Changed the quadrant and springs on the NFE WD 45 yesterday. Ordered new friction blocks too, they will go on when they arrive. Hydraulic lever was wanting to creep.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 2:34pm
Used the 170 and Woods to mow some pasture and building site focusing under walnut trees.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 9:38pm
This was actually yesterday at sunrise as I was windrowing beans with an agco-allis 9735 and a 6r30 pickett one-step. This was the only picture I took that would resize small enough to post for whatever reason.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 4:12am
Nice picture!
Tim NH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 8:46am
This is the 175 I got late last fall. I'm raking 3 windrows into 1. The last field of 3rd crop for haylage.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 12:41pm
Plowed and disced some food plots in for deer. Later than I would like but with tractor shows ,vacation and work this is the best I can do.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 5:21pm
Trimmed up the pasture with the D15 and NH451
Charlie
Post Options Post Options   Thanks (2) Thanks(2)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2026 at 5:25pm
Mowed hay with the 190XT, raked with the D14 and baled with the 6060
Charlie
TedN View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2026 at 9:49pm
We have been baling 3rd cut grass with the seriesIII and the 7000 the last couple days. I finally remembered to get a picture today.
I also have been doing a little work on the D14 as I get time, hopefully get the seat suspension redone and the new gauges in later this week.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2026 at 9:55pm
ted n what model is that new holland baler
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2026 at 11:26pm
That New Holland is a BC5080, the Case is a SB551 which is the same baler with different stickers. We also each have a New Holland 580 at the other farm, which are the earlier version.
Ted
mdcwells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdcwells Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 7:59pm
I took my D17 series one out to fix a little fence. As I backed back into the shop something went bang. The arms coming off the wide front axle fell off the bottom of the frame…..crap
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 5:29pm
Put away the Woods mower from the 170 and used it to drag out an old Bear Cat flail chopper. It's been on the place more than 25 years and I'd never seen it run. Remarkably it cut pretty well though the bottom of blower assembly is shot.
Edited by plummerscarin - 03 Oct 2026 at 6:20pm
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 5:40pm
Removed the bucket and installed the snow blade on the WD, then put it in the shop and checked all the fluids and topped off the hydraulic reservoir as it was the only one about a pint low.  Serviced, greased and lubed everything else so it will be ready when the white stuff arrives!!  I'll hook up to the rear blade later.
D17 LP with loader is all ready to go as well!
Edited by Alberta Phil - 03 Oct 2026 at 5:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 8:53pm
Not an allis but a challenger MT665D with a Colombo twin master bean combine. Just finished up the navy beans tonight. Will get going on the last 195 acres of great northerns tomorrow.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 8:58pm
We finished baling grass hay Thursday, so today I had a little time to work on the D14. As I got to the farm the neighbor stopped by. I had asked him about straightening the hood, and he had looked at it and thought it was doable. Not something that will happen right away, but nice to know that someone that knows how to do bodywork says it can be fixed. There are several things I want to do, but I decided to start with the gauges. Not very nice to start with.
I had ordered temp, oil pressure, and amp gauges from DJs and spent the afternoon getting them in.
I tested them after getting them in, and found that the amp gauge is wired backwards. I will fix it next time I have the dash out, which will happen soon.
I checked to make sure the tach drive and cable functioned, so I will get a tach before I take it apart again. I also need to get a better key switch, and would like to get a light switch in it and some of the wiring cleaned up. I also noticed the traction booster gauge doesn't work, so I may change it too.
I changed out the one front tire to a matching 3 rib and changed the oil and filter last week. I might see if I can get it on the hay fluffer tomorrow, we still have 35 acres of alfalfa down.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2026 at 6:11am
Used CA-2 to pull the grainhead out of the shed. Really need to get the charging issue figured out so I can use that thing more! 6080 moved several things out of the way so the head could get out.
TedN View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2026 at 8:20pm
More D14 today. I swapped the drawbar for the 3-point adapter and hooked it up to my Innes 450 bean windrower. First time doing anything with a snap coupler. I use the windrower as a hay fluffer for alfalfa, and it seems to work well. I have used it previously with the seriesIII, but thought I would see if the D14 could run it. It will lift it but gets very light in the front. I may eventually build a bracket to hang a suitcase weight out front, I think I want it easy to remove otherwise it will stay there when not needed.
Ted
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2026 at 9:00pm
Yesterday we finally finished baling for the year. I ran my seriesIII until the baler broke, then hopped in the 7000 to finish. Got done about 10:00. I did try running the windrower with the D14 even though we didn't need it just to see if it a possibility next year. It seemed to pull it okay, but I think it needs some adjustment on the raise/lower linkage. Cleaned off equipment today and started getting things unhooked, first time in 20 weeks the seriesIII hasn't had a baler hooked to it.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2026 at 5:42am
Pulled a wagon with 400+ bushels of beans in it into the building with the NFE 45.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 6:51pm
Today the 7030 got shut off valves on the heater hoses, completely drained of coolant and refilled with red ELC. I also cut about 6" off the exhaust pipe to get it close to cab height and put a rain cap on it. With the new block heater I put in Saturday it should be ready for winter.
Before (picture from auction listing)
After
Ted
Edited by TedN - 21 Oct 2026 at 8:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2026 at 10:25pm
Finally got around to adjusting the valve lash on the 6080 we bought this past spring. Anyone care to guess how far they were out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2026 at 5:00am
Loader work with the 6080 and cut the grass with CA-1.
3rdgen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 3rdgen Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2026 at 7:23am
I replaced the right front tire tube on the CA.  While it was on the jack, I noticed the steering arm needed some tightening, so I did that as well.
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2026 at 8:02am
Curious about this. Like that box of chocolates you never know what your gonna get. Sometimes, very few times, the PO did do upkeep.
I have a new valve cover gasket waiting to ck my 7060 I just got.
Edited by whatscooking - 29 Oct 2026 at 8:02am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2026 at 5:58am
Got Grandpa's WD out of the shed and drove it around! In all I had 7 Orange tractors out and moving yesterday, 3 Red ones, and moved 3 Cub Cadets into the shop! Also had a serious round of plow-tetris.
