What did you do with your Allis Today? |
Page <1 303132 |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4443 |
Posted: 26 Sep 2026 at 5:34am |
Changed the quadrant and springs on the NFE WD 45 yesterday. Ordered new friction blocks too, they will go on when they arrive. Hydraulic lever was wanting to creep.
plummerscarin
Posted: 26 Sep 2026 at 2:34pm |
Used the 170 and Woods to mow some pasture and building site focusing under walnut trees.
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 209 |
Posted: 26 Sep 2026 at 9:38pm |
![]() This was actually yesterday at sunrise as I was windrowing beans with an agco-allis 9735 and a 6r30 pickett one-step. This was the only picture I took that would resize small enough to post for whatever reason. |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3381 |
Posted: 27 Sep 2026 at 4:12am |
Nice picture!
Tim NH
Joined: 16 Oct 2012 Location: Lancaster NH Points: 1180 |
Posted: 27 Sep 2026 at 8:46am |
This is the 175 I got late last fall. I'm raking 3 windrows into 1. The last field of 3rd crop for haylage.
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 5048 |
Posted: 27 Sep 2026 at 12:41pm |
Plowed and disced some food plots in for deer. Later than I would like but with tractor shows ,vacation and work this is the best I can do.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6381 |
Posted: 27 Sep 2026 at 5:21pm |
Trimmed up the pasture with the D15 and NH451
Charlie
Charlie175
Thanks(1)
Posted: 27 Sep 2026 at 5:25pm |
Mowed hay with the 190XT, raked with the D14 and baled with the 6060
Charlie
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 376 |
Thanks(1)
Posted: 29 Sep 2026 at 9:49pm |
We have been baling 3rd cut grass with the seriesIII and the 7000 the last couple days. I finally remembered to get a picture today.
![]() I also have been doing a little work on the D14 as I get time, hopefully get the seat suspension redone and the new gauges in later this week. Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4242 |
Posted: 29 Sep 2026 at 9:55pm |
ted n what model is that new holland baler
TedN
Posted: 29 Sep 2026 at 11:26pm |
That New Holland is a BC5080, the Case is a SB551 which is the same baler with different stickers. We also each have a New Holland 580 at the other farm, which are the earlier version.
Ted |
mdcwells
Posted: 30 Sep 2026 at 7:59pm |
I took my D17 series one out to fix a little fence. As I backed back into the shop something went bang. The arms coming off the wide front axle fell off the bottom of the frameā¦..crap
plummerscarin
Posted: 03 Oct 2026 at 5:29pm |
Put away the Woods mower from the 170 and used it to drag out an old Bear Cat flail chopper. It's been on the place more than 25 years and I'd never seen it run. Remarkably it cut pretty well though the bottom of blower assembly is shot.
Edited by plummerscarin - 03 Oct 2026 at 6:20pm |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 4023 |
Posted: 03 Oct 2026 at 5:40pm |
Removed the bucket and installed the snow blade on the WD, then put it in the shop and checked all the fluids and topped off the hydraulic reservoir as it was the only one about a pint low. Serviced, greased and lubed everything else so it will be ready when the white stuff arrives!! I'll hook up to the rear blade later. D17 LP with loader is all ready to go as well! Edited by Alberta Phil - 03 Oct 2026 at 5:41pm |
Acguywill
Posted: 03 Oct 2026 at 8:53pm |
![]() Not an allis but a challenger MT665D with a Colombo twin master bean combine. Just finished up the navy beans tonight. Will get going on the last 195 acres of great northerns tomorrow. |
TedN
Posted: 03 Oct 2026 at 8:58pm |
We finished baling grass hay Thursday, so today I had a little time to work on the D14. As I got to the farm the neighbor stopped by. I had asked him about straightening the hood, and he had looked at it and thought it was doable. Not something that will happen right away, but nice to know that someone that knows how to do bodywork says it can be fixed. There are several things I want to do, but I decided to start with the gauges. Not very nice to start with.
![]() I had ordered temp, oil pressure, and amp gauges from DJs and spent the afternoon getting them in. ![]() I tested them after getting them in, and found that the amp gauge is wired backwards. I will fix it next time I have the dash out, which will happen soon. I checked to make sure the tach drive and cable functioned, so I will get a tach before I take it apart again. I also need to get a better key switch, and would like to get a light switch in it and some of the wiring cleaned up. I also noticed the traction booster gauge doesn't work, so I may change it too. ![]() I changed out the one front tire to a matching 3 rib and changed the oil and filter last week. I might see if I can get it on the hay fluffer tomorrow, we still have 35 acres of alfalfa down. Ted |
IBWD MIke
Posted: 04 Oct 2026 at 6:11am |
Used CA-2 to pull the grainhead out of the shed. Really need to get the charging issue figured out so I can use that thing more! 6080 moved several things out of the way so the head could get out.
TedN
Thanks(1)
Posted: 04 Oct 2026 at 8:20pm |
More D14 today. I swapped the drawbar for the 3-point adapter and hooked it up to my Innes 450 bean windrower. First time doing anything with a snap coupler. I use the windrower as a hay fluffer for alfalfa, and it seems to work well. I have used it previously with the seriesIII, but thought I would see if the D14 could run it. It will lift it but gets very light in the front. I may eventually build a bracket to hang a suitcase weight out front, I think I want it easy to remove otherwise it will stay there when not needed.
![]() ![]() Ted |
Page <1 303132 |
