What did you do with your Allis Today? |
Page <1 293031 |
| Author | ||
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 356 |
Thanks(1)
Posted: 02 Aug 2026 at 11:23pm |
I got to run my seriesIII today, baled grass hay. The 7000 was on the other baler. We lucked out with conditions, there are several fires around us so it doesn't matter which way the wind blows we have smoke. Had enough wind to hold the dew off and not quite blow the windrows away. We had the rakes, two balers and the harobed all going at the same time. Sixty acres raked, baled and stacked before the weather got bad.
Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
| Sponsored Links | ||
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5690 |
Thanks(1)
Posted: 05 Aug 2026 at 11:21pm |
![]() Spent the last 3 afternoons sickle mowing our pasture fields on my D17 Diesel. Having the 82S makes mowing so much more comfortable since I don’t have to keep turning around to see the mower. The Buda never went over 180 degrees with the temperatures being in the high 80’s and high humidity. |
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 430 |
Posted: 06 Aug 2026 at 2:15pm |
I drained the water out of the radiator and block and replaced with 50/50 anti freeze. I thought I should do it while I’m thinking of it before I forget and it freezes in the middle of December.
'41 Allis B
'49 Farmall Cub |
AC720Man
Thanks(1)
Posted: 06 Aug 2026 at 5:10pm |
![]() Used my 720 and sickle mower to trim our river property. She works just like her bigger version the 82S. Being compact I can get into some tight areas. |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4222 |
Posted: 08 Aug 2026 at 3:53pm |
nice rig hows the fishing
AC720Man
Posted: 08 Aug 2026 at 8:55pm |
Kinda slow due to the heat, water in the low 80’s. Caught some largemouth bass a few days ago but no size. Caught a 4 pounder in the spring.
TedN
Thanks(1)
Posted: 14 Aug 2026 at 4:48am |
I ran my 7030 pulling a baler, first time I have run it since I baled with it last month. I learned a few things about it. The right rear tire had a leak and was nearly flat. I decided to change the water valve, found that the one I took out had a disintegrated oring, so I may have fixed the leak. I had changed the air filters and considered doing the fuel filter but was short on time and didn't want to reprime the fuel system, but I found that sitting a month it lets a little air in so I had to reprime it anyway. I think I need to come up with some more things for that tractor to do so it gets used a little more.
Now the exciting part, saw a meteor a little before 1:00am pacific time. It lit up the sky bright blue like a giant arc welder and lasted about ten seconds. I have seen meteors before but never have seen one that bright. It was East and North of us, but impossible to tell how far. Edit to add - What I have read about the meteor is that it broke up over Sims Corner, about sixty miles north of where I was baling and was probably only ten miles east when I first spotted it. I had just stopped and was getting out of the cab to check twine when the sky lit up. I expected to hear a sonic boom but didn't, I must have been just outside the cone. It was bright enough to be seen from Vancouver Island to Spokane, WA and probably beyond. Ted Edited by TedN - 15 Aug 2026 at 8:36pm |
dr p
Joined: 24 Feb 2019 Location: new york Points: 1675 |
Posted: 15 Aug 2026 at 7:37pm |
Got all the neighbors triticale combined with the 60 we resurrected. Need to decide if i am going to use it to harvest by soybeans or my 66. Those three inches and 8 extra bushels in the bin seem like a big deal.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4422 |
Posted: 21 Aug 2026 at 5:22am |
Got it stuck in the creek! The 185 I was bush-hogging with that is. Had to walk back to the shed and get the 856 to pull myself out.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 4016 |
Posted: 21 Aug 2026 at 9:14am |
Used the WD with the bush hog to mow out the west fence line and clean up the pasture edges. With the record rainfall this summer, the grass, weeds and tree suckers were getting pretty tall. Had to ride the hand clutch when cutting got really heavy. Almost needed armour for the hordes of mosquitos!
TedN
Thanks(1)
Posted: 21 Aug 2026 at 10:55am |
I finally had opportunity to bale at night with my seriesIII. It has been over a year since I updated my lights, and this was the first time I used them. My brother has used it a couple times at night, and I have baled grass hay in the daylight but I was starting to wonder why I had put them on. I have them wired to the original light switch and set up so I can turn it back one click and shut off the light bar in the front if I happen to be aimed at the other tractor. I also got to try out my camera at night, it is nice to be able to see what is on the other side of the dust coming from the baler. I was concerned the display might be too bright and I would have to figure out how to dim it, but it wasn't a problem at all. The downside to all this is now I know what it is like to have lights and camera, so I need to get the rest of them upgraded.
Ted |
AC720Man
Posted: 21 Aug 2026 at 4:52pm |
Ted are you round baling or square baling at night? I could never do that here on the east coast. An hour before sunset here and the humidity starts to set in and the hay becomes too tuff to square bale. Do you use additive for instance silo king?
Edited by AC720Man - 21 Aug 2026 at 4:52pm |
TedN
Posted: 21 Aug 2026 at 9:11pm |
Small squares, 16 x 18. From what I understand we are one of the few areas of the US to use that size, and not many that still do. We are in a desert climate and don't get the humidity. With the small bales we don't use anything, but almost everyone that does big bales does. Our market is bale sales, so we try to get to 90# bales in alfalfa, a bit less in grass. If we were selling on a per ton basis they would be heavier.
Ted |
HudCo
Posted: 21 Aug 2026 at 10:18pm |
my baler is a 16 x18 we rarely have any dew any more , ever enought to shut it down any more
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5009 |
Posted: 22 Aug 2026 at 11:18am |
Come on Ted your going to have to try harder. Locally you can buy 3 string alfalfa bales at 90 pounds. Including all the cobble rocks too ![]() . Well maybe not the rocks, that family has given up alfalfa for pistachio trees. I have no idea how small they had made the bale chamber. My son worked at a ranch that bought them and got to wondering and weight some. And a weekly chore to take a bucket and clean the feed bunk of rocks.Three string bales started as 16x23 and the first round of shimming was 15x23. I have read Freeman balers could be bought factor as 15x22. But don't anyone with one.
TedN
Posted: 22 Aug 2026 at 1:26pm |
I learned to bale helping my granddad who had grown up during the depression. If the bale was a little heavier the twine cost and stacking cost went down. We ran New Holland 285s, so the heavier bale helped keep the bale square too. We used grade 8 bolts for the shear bolt, and if you couldn't see the baler frame flex a bit the bales were too light. For a long time I wondered how people could move the three string bales, because they had to be heavier than the 120# 2 string bales we were making. Come to find out you can bale without making the baler frame flex every stroke. The things you learn as you get older! Edit to add the first load of the third cutting we baled a week ago went out yesterday with a 107# average bale weight. Ted Edited by TedN - 23 Aug 2026 at 5:51pm |
AC720Man
Posted: 23 Aug 2026 at 8:34pm |
I’ve read Ted’s post 3 times. Am I understanding that your bale weight is 90-107 pounds in a small square?
TedN
Posted: 24 Aug 2026 at 6:03am |
Yes, that is correct. 16"x18"x46"-48" length, our climate allows drydown to about 12% moisture then we need a little dew to bale. We have had fourth cut average over 120# a bale. We usually get four cuttings per year on alfalfa, three on the grass hay. If you forget to back the tension off between grass and alfalfa you will get bales so tight you can barely get your fingers between the strings and bale, but you will notice that when you are replacing your shear bolt.
On the Allis topic I have started getting a few things ordered for my D14. We have some alfalfa to plant soon, and it seems to be well suited to the drill. Probably be winter before I pull the sides off to change out the gauges and rework the wiring though. Ted |
Les Kerf
Thanks(1)
Posted: 24 Aug 2026 at 7:34am |
That sounds about right to me; in years past I bought quite a bit of alfalfa from the Columbia basin and it always ran right at 100 pounds per two-string bales. I bought hay from a fellow at Post Falls, Idaho several times, he used a Freeman baler that made 3-string bales at 150 pounds per bale.
AC720Man
Posted: 24 Aug 2026 at 9:33pm |
I have never heard of small squares weighing this much. My first thought is moving them, loading them. Feeding them also.
Les Kerf
Posted: 24 Aug 2026 at 10:33pm |
I worked for a neighbor back in the early 1970's, he had a wire tie baler and he always insisted on his alfalfa bales being 100 pounds; you had to be careful and not jerk the wires too hard because they would break. When I fed the hay to his milk cows I pulled the wagon up to the feeder and when I tossed the bales into the feeder I just gave the bale a quick yank and both wires would break. The boss always set the bales up on the feeder and cut the wires with pliers; when he saw me breaking them he just shook his head and walked away
Oh to be young again! ![]() |
TedN
Posted: 24 Aug 2026 at 10:46pm |
We don't really have a local market, everything gets hauled out on a truck. I assume that is why we make heavy bales, and also why round balers aren't all that popular. The few diaries that are around here chop most everything that they use.
Ted |
AC720Man
Posted: 25 Aug 2026 at 10:04am |
Interesting how things are done in different parts of the country. We make 37” long bales and strive to produce 37-38 pound square bales for our customers. Several customers are women and they request lighter bales. Years ago we normally baled 42-45 pound bales. More women are involved now with horses or cattle. Man I wouldn’t want to load those 100 lb bales lol! We still hand stack our wagons.
Ray54
Posted: 25 Aug 2026 at 11:28am |
Very interesting about the regional difference in hay bales wanted. Sometime in the late 1960's commercial hay haulers more or less refused hauling anything but 3 wire bales, in California. Until the plastic twine was in use, I would guess about 1 in 100 balers was twine. Part of the 3 tie argument is if one breaks you still have a bale if you are careful. And taking the back out of loading 120 pound bales, with a hay boom was also a reason for heavy bales. The more weight in each bale the less bales to load.
Hopefully this works Bing Videos an example of how it was done. Nothing against the guys in video, but in the day if they did not have 420 to 460 bales on a set of double trailers and be tied down in less than 2 hour something was wrong. By 1980 the hay squeeze was making in roads in the loading of hay. I think it was Freman hay equipment company that had the first hay squeeze device. But it started as their machine to compete with the New Holland automatic bale wagon, or the west a Harrobed. The Harro came from the original inventor of the automatic bale wagon. He was a commercial hay producer in the Calif central valley, he had 5 daughter that helped haul hay until they grew and moved away. The harro is the first letter or their first names. The Freman bale pick up machine loaded similar to the NH model. It unloaded by squeezing the bottom of stack and then sliding it off the back and setting it down. Until some took the idea of sliding it back directly onto a truck. The squeeze rails on the front of a forklift. Then forklift mast on a truck chassis. And soon the built from scratch units by Road Runner. So on a good day, a bale in the field, into the barn, onto a truck, delivered to customer has never been touched by a human. Making sure video linked, and watched the vid again. I would guess they are building a 50 to 70 block of hay to be picked up with a hay squeeze. Which was a common thing in the early hay squeeze days. The NH 1065 was the first NH do squeeze block stacking, but was not liked that well on the farm. The 1075 model is still popular. Edited by Ray54 - 25 Aug 2026 at 11:35am |
Les Kerf
Posted: 25 Aug 2026 at 9:47pm |
One old fellow I used to buy hay from hauled it in to Idaho from the Columbia basin on a flatbed semi, he had what he called a 'Boomer Truck' that he used to off-load from the semi trailer directly onto my truck. This Boomer truck was a 3/4 ton pickup with a tall boom/derrick contraption mounted in the back and it had a winch arrangement powered by a Briggs & Stratton engine (maybe 10 HP). The winch was loaded with a rope rather than cable, and had a large, special shaped hook that he stabbed into a hay bale. The hook had another rope attached to it that he kept hold of with one hand so he could pull the hook back up to stab another bale. His other hand held onto a rope that activated the winch. The winch used a continuously spinning center that used expanding brake shoes to engage the drum; by pulling on the control rope he could feather it so as to either raise or lower the load. The Boomer truck sat right beside the semi and I backed my 1-ton truck under the boom so that when he lowered the bale it dropped right on my truck. If the bale landed just right he could usually yank the hook out himself but sometimes I had to pull it for him, then he hauled the hook back up onto the load where he was standing and stabbed another bale. This all sounds rather clumsy and slow, but I'm here to tell you that when the hook came out of that bale you had best be hustling to get it set in place because there was no free time available to pick yer nose before another 100 pound bale of good Columbia basin alfalfa was swinging down to land with a thump right where the last one hit. That ol' geezer was a true master of his trade, and he made it look easy. It didn't take long to drop two tons of hay onto that old Ford and be tying it down. This was 30+ years ago when I was still young and agile, I sure couldn't keep up today!
Ray54
Thanks(1)
Posted: 26 Aug 2026 at 10:38am |
Hay booming another profession that came and went in the blink of the eye. And a west coast thing at best.
Last time I went to the antique tractor show at Tulare California they still had contest to see who could move 20 or 30 bales the fastest with the hay boom. They were not the old time smooth professionals. But if anyone has interest there were other contests that where on you tube from the old Los Angles dairy district, I think Antelope Valley Fair. But anyone that boomed hay for a living has to be in their 60's today. As most are well over 70 by now. They prided themselves to put the bale were in was to be, generally a bump from the truckers knee was all that was needed to end up with tight square stack.
TedN
Thanks(1)
Posted: 31 Aug 2026 at 9:15pm |
I forgot that this thread took a turn, I meant to try to get some pictures and start a thread on the hay loading. My brother still has a boom loader and loads occasionally, but usually hires it done. Big bales and squeeze blocks have made loading small bales a thing of the past.
Back to what I did with my Allis today - I decided the D14 could use a little bit of attention, so I ordered a seat shock and bushings, and new gauges for it. I bought a three rib front for it so it will have matching fronts, maybe this weekend I can start working on it. Ted |
bigstone
Posted: 05 Sep 2026 at 8:00am |
Plan on using the WD45 to do some brush hogging today.
dr p
Posted: 07 Sep 2026 at 7:40pm |
Remember that post in july when the rotobaler ate hay like no ones business. Today i brought out a project rotobaler and i knew it was going to be an unproductive process but two hours, 8 bales and only three with string. What in heavens name made me think i need two working rotobalers is beyond me.
TedN
Posted: 13 Sep 2026 at 10:49pm |
Not a lot of tractor things this weekend, it has been cold and wet. I replaced the primer plunger in my 7030 and changed the fuel and transmission filters. My power steering works at idle now, so I think the filter must have been plugged. It also had just a little pop to the exhaust at idle before and now that is gone. I think with the leaking plunger and partally plugged filter it had been pulling enough air through the plunger to push a bit out to the injectors at slow speed.
Ted |
Page <1 293031 |
