WD45 engine
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: WD45 engine
    Posted: 20 Oct 2019 at 8:15am
Good running engine still in the tractor so can hear it run. Has an exhaust leak I have other manifolds if it needs one. I want the flywheel clutch and water pump off from it. Otherwise it's complete. This engine has low hours on it since a rebuild good oil pressure. Unsure if it has an overbore in it or not but I could find out. I would like 600 dollars for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2019 at 7:24pm
Make an offer needs to go for other projects.
37WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 37WC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2019 at 10:35pm
Send me a text about the engine 9062507983 thank you,
Edited by 37WC - 09 Nov 2019 at 10:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 9:41am
still for sale. 130-140 lbs of compression warm. 4 1/8 dished pistons. Runs good starts right up even cold.
MarkIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:12pm
Maybe interested in WD45 engine. text 765-432-0344 Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2019 at 12:59pm
Sold pending payment
This page was generated in 0.182 seconds.
