Wc vs wd45 |
farmer_rob
Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 362 |
Topic: Wc vs wd45Posted: 10 Feb 2013 at 8:10pm |
I was wondering which tractor would make for a more competitive tractor if they had the same tires and engine. The wc would be able to be made lighter 120 NF. The would have lower gears. I already have the NF wd45 but was thinking of changing
if farming was easy everybody would be doing it
Posted: 10 Feb 2013 at 8:27pm |
Low gear on a WC is a faster ratio than any WD45 low gear. Second gear in WC is still a bit faster than a WD45. WC engine RPM's are slower than a WD45 if rules put limits on engine speed.
farmer_rob
Posted: 10 Feb 2013 at 8:45pm |
Ok would that mean that the wc wouldn't pull aswell in the heavier classes is all other variables are the same including engines
Posted: 11 Feb 2013 at 6:39am |
More HP solves that little problem !!!
