WC timing
Driverdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Topic: WC timing
    Posted: 02 Aug 2026 at 7:58am
   I am working on the 1940 WC ( that my late father bought 1952). I have put (and adjusted) points in the magneto and am getting good spark. I now want to install magneto. I have number one cylinder top dead on compression stroke, but cannot find fire mark in inspection hole in clutch cover!?!?...does one exist, or am I missing something? Thanks in advance...Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 9:19am
look real close... maybe wire brush the area... very faint mark...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 12:48pm
...Steve, that k you very much! Exactly what I was looking for, now I have a better idea what to look for ( and I may need that wire brush!)..Thanks again...Dan
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 2:36pm
A hint. The (set) bolt on the front crankshaft pulley will be straight up when the crankshaft is at TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 6:30pm
Thank you WF...that also is a valuable piece of information!.... Dan
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 12:22am
Once you have the mag installed, turn the engine over slowly with the hand crank.  You can be comfortably satisfied that you're in the 'right range' when you turn the handle, feel compression peak, then just START to let off, when you hear the CLACK!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 11:42am
WC now running like a well made watch from a European mountain country! Thank you very much friends! Only question was, to be at top dead center with flywheel marks lined up....crankshaft pulley bolt points straight down??..?? Thanks for help. Dan..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 11:54am
Down for #1 and #4. Up for #2 and #3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Driverdan Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 12:13pm
Aaahhh...that makes sense..Thanks Doc!...Dan
Edited by Driverdan - 03 Aug 2026 at 12:14pm
