Wanted Loader brackets
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: Wanted Loader brackets
    Posted: 17 Apr 2021 at 6:44am
I'm looking to find a pair of the rear mounting brackets for a 400 series loader on a d14/15 tractor. The RH bracket would be 70344904 or 343362. The LH bracket would be 70344905 or 70343363. Even just 1 would be a big help.
Edited by PaulB - 18 Apr 2021 at 6:50am
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 9:45pm
I easily made some for D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 6:51am
D17 brackets are just a bent piece of angle, completely different from the weldment for a D14/15.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 8:11pm
OK Paul.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 9:51pm
This is what the D14/D15 brackets look like.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2021 at 10:01pm
Paul...Did you get this resolved...Dale
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 8:11pm
Here are some pictures of my 415 on my D15II, when I bought it the owner said he bought the tractor and loader new at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 8:44pm
Yep, that's what I'm looking for.
What is the size and thickness of the angle that they are made from?
Edited by PaulB - 17 May 2021 at 8:46pm
Gary View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 3:55pm
Paul
Took some measurements of the brackets of my 415 loader.
Mine are like those in the actual orange pictures, which you note are different from the sketch from the Parts Catalog.
The Horizontal piece: 2 1/2 X 3"
10" long L, 3/8" thick, 2 holes 7 1/8" apart.
The horizontal side with holes is 3" wide, vertical side is 2 1/2" high.
Sloped piece with 'U' bolt: 3 1/2 X 3 1/2"
9 1/2" long, 3/8" thick, welded to Horizontal piece @ 45'
'U' Bolt is 3/4" diam.
The welded position of the sloped piece would be critical because the frame is bolted with 3 bolts to the Engine side frame / rail.
Probably best to assemble everything in position and tack weld first.
HTH
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 7:06pm
Thanks: That give me something to go on if I'm unable to find a pair.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 8:22am
   If you can't find a u bolt an angle iron with holes drilled will work on top, then use bolts.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 1:54pm
I think we have some NOS ones here.  I will try to get a picture of them.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 4:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 4:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 4:24pm
Shipping tag number says 387416.
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 6:44pm
I have a pair of those brackets and did not even know what they are till now.
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 6:49pm
Jim
  Show off
  You been holding out on me again I see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 6:55pm
Originally posted by Gary Gary wrote:
Paul
HTH
Gary
  Gary thanks for taking the time to measure the bracket, I'm dealing with a leg injury and don't know if I could've got the measurements but would've tried if you didn't post them.
Edited by Kenny L. - 19 May 2021 at 6:56pm
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 9:05pm
Jim
  Show off
hahaha! That was pretty awesome of Jim! Just like magic!
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2021 at 11:52pm
Kenny, I can't give you all my secrets!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2021 at 6:51am
  I know buddy, you've been good to me over the years with your secrets, see you Saturday.
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 9:27am
Gents, I bought a 400 loader with I think 45 brackets.  Wondering if either somebody has the D15 brackets for sale or if I could get a little more detail on the U bolts.  Is that 7-1/8" spacing (Gary mentions above) on center or inside dimension?
Thanks for the help.
