Wanted, D17 diesel block
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: Wanted, D17 diesel block
    Posted: 03 Sep 2020 at 6:57am
Looking for a block for a D17 diesel. PM or text 217 898 6139
Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 7:09am
What age tractor ?? What style water pump ?? You want a gas block if possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 7:25am
1958, water pump, not sure about that. there is a hole in the center of the block on the left hand side. Cant post a pic yet. Open to any ideas
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 10:48am
I Used a Gas block on my D19 Diesel and all the liner protrusions were right on.
Is your water pump mounted on your block or cylinder Head?
there is one on Ebay for $400.  Link:
ALLIS CHALMERS D-17 6 Cyl 262 ci 4.3L Bare Engine Cylinder Block 4516682 Diesel
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 11:36am
So a 262 gas block can be used as a diesel block? Didn't know that.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 12:35pm
The D-19 came out in late 1961. At that time the water pump went from the cylinder head down to the front of the block. I would imagine the D-17 engine got the same change at the same time. All D-19's were 262- wet sleeve engines with the water pump mounted on the block. That means gas-diesel and LPgas were all the exact same engine block. Gas/LP blocks are perfect for a diesel restoration, as the lower compression ratio hasn't pounded the sleeves below flush. Unfortunately, AC never had a 262 gas version in the old block/water pump design that they used in farm equipment. There sure could be such a thing out there on a gen set, water pump, etc.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 12:47pm
you can have the block decked a few thou and recut the counterbores.  if you get another block i would sure have it checked before just throwing parts in.  We were going to have our block decked but it had cracks so we went with a gas one.  still ended up taking a couple thou off the top to get all liners +.004.
Edited by CAL(KS) - 03 Sep 2020 at 12:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 6:39pm
Not sure how much you can deck the block without having to cut the same amount off of the pistons. Pretty sure things get really close when the block gets decked very much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 10:08pm
You can use the later style block with the early head. I have a later gas block in my early D17D with the pump on the head. I just made a block off plate for the block pump and from there it's the same besides the turbo drain hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 6:40am
I could use a d19 gas block, close to east central Illinois.
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 9:25pm
Got a few blocks in Nebraska. Ryan at 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2020 at 5:30am
Found one! Thanks for all the help.
Randy
This page was generated in 0.089 seconds.
