Variable Speed
A-C_220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C_220 Quote  Post ReplyReply Direct Link To This Post Topic: Variable Speed
    Posted: 30 Sep 2019 at 3:03pm
Is the variable speed useful for lawn/garden tractor pulls, or does it just slip? Thanks for any help.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 8:50am
I don't know, but because no one has answered, I'll say this. I have a 720 that has a 3 speed gear box and hydro. It has a loader on it and I can stall it when scooping out of a pile of soil that has been setting for a few years.
Dusty
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2019 at 11:04am
Mine slips just in regular use. Belt is correct width. Not worn enough to replace. Adjusted as best I can, so I will live with it.
Perhaps someone else will respond with more complete info for you.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 9:12pm
pulling a sled makes alot of things happen (bad things) that would not happen even if you were plowing or other heavey work  but i would like to purchase a good varible set up and try to make it work on my 101
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2019 at 10:58am
If the vari-speed is tight like new it doesn't do to bad. When sheves and pins are worn and loose it will slip! We put double spring on one to help!
This page was generated in 0.104 seconds.
