Uneven cut and bad deck vibration - time for new b
Ricky38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky38 Quote  Post ReplyReply Direct Link To This Post Topic: Uneven cut and bad deck vibration - time for new b
    Posted: 22 Sep 2026 at 5:05am
Hey everyone. I run a small bean farm and use an older riding mower to keep the paths clear between outbuildings, but engines and equipment really aren't my strong suit. Lately, the mower leaves high spots everywhere and vibrates pretty badly whenever I hit thick grass. I crawled underneath and saw the edges of the blades are totally nicked up, pitted, and dull. I was looking around online for lawnmower blades for sale so I can just swap them out, but I wanted to ask how difficult the job actually is. Is it as simple as wedging a block of wood under the deck and unbolting them, or do I need special tools to get the new ones torqued down right? Any beginner advice would be great.
upd: i found good lawnmower blades for sale here - https://udcparts.com/collections/mower-blades, you know something about them?
Edited by Ricky38 - 23 Sep 2026 at 4:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 7:47am
yes, you can block it with wood, then put a wrench on the bolt and SMACK it with a hammer to loosen......... I assume you dont have an air impact with an air compressor.. those work great !!.... same to reinstall..
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2026 at 5:38pm
Ricky 38
Would a good blade sharpening help/be a good place to start?
I purchased a 1979 716H with a 48 inch deck, a couple of years ago, original blades but very dull.  The deck bearings were bad, too much play causing vibrations.  I replaced all six bearings spindle bearings - lots of choices online, I sourced from local Simplicity dealer
No more vibrations and the sharpened blades work fine
Replacing the deck spindle bearings take some time - lots of good YouTube examples
Just passing on my experience
The Allis Chalmers/Simplicity tractors and mowers were built like a brick XXXXhouse!!! However, some maintenance required
Good luck with your project
Here is my deck
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2026 at 7:09pm
vibration could be blades but uneven cut might be deck bearings .
To balance blades after sharpening they sell a little cone type tool to set blades on - work good , have a plastic one and metal one I have picked up over years .
 the 60" mower I have was giving uneven cut - found the bolts to the spindle were lose and belt was pulling spindle off flat to deck - fixed that and then also had to straighten blades on hyd press .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2026 at 2:35pm
Could have the Alternate Mower I have here, Stump in the way just drive over, Large Rock, Rinse Repeat, Deck is out of Line from wedged Large Chunks being applied, belts get torn up fast trying to Clear what is Jammed.  Our 2305 Deere needs a replacement 62C Deck ASSEMBLY, near as to the same price as a different mower.  Used decks the sales people will state could be in same shape as ours.
