Truck oil change
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Truck oil change
    Posted: Yesterday at 5:55am
Did my truck yesterday
I'm 73 and had both knees replaced. Plan to keep doing my own oil changes as long as I can, but I'm beginning to think it won't be much longer. Any thoughts? Thanks
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:00am
I like to use the shop vac for assistance when pulling the oil pan drain plug.
I place the catch pan under the drain plug, loosen the plug, place the shop-vac pickup hose onto the oil fill port on the valve cover, turn the vac on. Remove the drain plug then shut the vacuum off. Hands get no oil on them and no splash into the catch pan.  The Ford 7.3 has over 15 quarts of oil, so I don't like to spill any.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:57am
Four post hoist. Drive vehicle on. Raise up. Drain oil and change filter. Let down and fill with oil. Never have to bend over or get down on your knees. Problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:09am
i still do the truck and car at 73 years old... Got both original knees ... but YES, it is begining to be a chore to "get back up" when you laying on the ground..
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:19am
I'm 69, still do my truck, all original parts, however, left knee and hip aren't as limber as before.  Send the wife to the dealership with her car, too low to the ground, even on ramps, and I'm out of the crosshairs if it isn't done in her timeframe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:32am
15 quarts! That's a lot, good idea with the shop vac. My truck holds 8 quarts. Dr Allis,a lift sure would be sweet. Thanks guys
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:00am
I have been installing Fumoto quick drain valves on my vehicles; they don't help with the problem of old age and bad knees but they do minimize the time and effort underneath the rig. Plus, I can slip a hose over the valve and direct the stream to reduce splashing. I like to drain the oil while hot and let it drip over night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:50am
Our KW I equipped with Quick Drains, flip a Locking handle and it Drains, my old 7.3 also 15 quarts I can still access under I also change as do the Deere 2305 and my 180. Old Impala, Tire shop with Post Lift, tires rotation inspect brakes and oil change cheap as to mess! Wife’s Explorer same shop. He had a Clients SUV in the other day, adds 1/2hr charge to Drop the Splash Pan to access engine, new crap, NOT buying!!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:52am
YEP!! No regrets getting one. Add to that a catch can on wheels to roll under the drain plug, raise the funnel and no mess. The can has an air fitting so I can pressurize it to unload into my cousins waste oil furnace barrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:16pm
That is the way to go if you are doing your own oil changes or doing it for others. Wish I had a place here where I could put in a lift. Since I am old, fat and lazy I have been taking my vehicles to the local tire shop for a number of years. I furnish the oil and filter and they do the labor along with checking the brakes and tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:21pm
Looks like a good idea Les. I did crawl under my truck only to realize I'd left the plug on my bench !! Thanks guys
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:01pm
Grandson does my oil changes on the lawn mowers, tractors and the pickup, but mamas goes to the dealership.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:24pm
I do mine with a oil sucker, like they use on boats.  It goes in through the dipstick, you don't have to pull the plug, there's generally only 1/2 cup or so left in the pan.  Every other change, I do take the plug out, just to get it all out, once in a while...Wink
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 36 minutes ago at 6:08am
I use a couple of the ideas above.
When I built my garage, my son-in-law talked me into building it with 16' ceilings and buying a lift. I poured the concrete in preparation for a two-post lift that I found online. (I had first thought about a pit, but my insurance company said they would cancel my insurance if I put in a pit.)
When I went to pick up the two post lift, the guy who was working in the business noticed my dually diesel pickup. He told me the arms on a 9000 lb. two-post lift were not heavy enough to support a diesel and I should go to a (much more expensive) 12,000 lb. lift. He asked me what I was going to do with the lift and recommended an extra-long, extra-wide and extra-tall 9,000 four post lift. He was quick to point out that vehicles do fall off two-post lifts.
I bought the four-post he recommended, along with a rolling jack and have never regretted it.
Like Les, I have used Fumoto valves in all my vehicles for over 20 years.
A local big truck repair owner told me that every truck he does the maintenance on gets a Fumoto valve installed. He said some of his mechanics tend to overtighten oil drain plugs and after paying to replace some oil pans on big trucks, they decided to go to Fumoto valves on everything.
The ones I buy has a nipple for a plastic hose, so I have no spillage from the drain plug (I wish I could say that about the oil filter). They are relatively inexpensive and make draining oil much cleaner and easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 2 minutes ago at 6:42am
Lots of good info. Thanks guys!
