720 progress pics |
RLBPA1
Joined: 04 Mar 2012 Location: Somerset PA Points: 287 |
Topic: 720 progress picsPosted: 05 Mar 2014 at 7:20pm |
![]() ![]() Bought it in November. Hasn't run in 10 + years. New Stator, regulator, rectifier, repaired wiring harness, rebulit carb and fuel pump, head gaskets, replacment intake manifold. new oil cooler lines. lots of claening. Now has good spark, 100 PSI compression in both cylinders. Will soon be ready to fire up. |
Seth Souerdike
Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
Posted: 05 Mar 2014 at 8:36pm |
can't wait to see her all done :D
There are no atheist in foxholes.
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2103 |
Posted: 09 Mar 2014 at 4:12pm |
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 09 Mar 2014 at 11:30pm |
Gol darnit, Dennis - always showing us some of the many you have! Some of us feel very, very lucky to even have one! LOL! (and it took me about 7 years to get just one!)
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1907 |
Posted: 10 Mar 2014 at 5:33pm |
dennis, what did you use for the narrow front?
Posted: 10 Mar 2014 at 6:17pm |
The narrow front was a mix of several items from around the shop.
The stem was from a "G" front end. The axles are the "spikes" or whatever you call the rods that help pull a crop into a combine cylinder. The rest is just metal for reinforcing, etc. The front end is not welded to the tractor, only bolted with just 2 holes need to be drilled. Front end could be moved to another tractor in about 2 hours would be my guess. Really the only thing I had to buy was the rims and tires. Den |
