Wc brakes
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Topic: Wc brakes
    Posted: 25 Feb 2014 at 3:42pm
Are the brakes on a unstyled wc wet or dry. One side has oil in it the other does not. Do I have a bad seal letting it in or out. If they are wet is it the oil out of the rear end or do I have to run something else.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2014 at 3:45pm
Dry.  Probably have a seal going bad.  You can log on to www.agcopartsbooks.com as a guest and type in WC.  That'll get you to the parts manual.
AaronSEIA
