mower from b 12 to 710
wildbill26 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Topic: mower from b 12 to 710
    Posted: 28 Jan 2014 at 9:56am
this is probably a long shot but wondered if the sicklebar mower from my b 12 would work on my 710, i know it would bolt in place but since the pto set ups are some what diffrent i wondered if it work work that way. i only wanted to swap it since my 710 is a 6 speed and has more gearing options, slower, thanks bill
1950 wd wide front w loader
1940 b, 1939 m crawler
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 11:58am
No. The 710 will run the mower too fast and will tear it up in no time. The sickle mowers for the 700 series have a special planetary gear reduction setup to reduce the speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 12:00pm
Thank you Chris,I definitely don't want to.mess anything up
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 3:03pm
I took the 6 1/2" pulley off the trans and installed a 9" one and a new belt. There is room to put a 10" one on if you like. It doesn't take long to switch back and forth between the stock pulley/belt and the bigger one. A bigger pulley slows down the tractor quite a bit and may be just what you need. Sure slowed down my B-10 for tilling.
The mechanic always wins.
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 3:06pm
He is talking about the mower RPM not the ground speed..
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 5:25pm
Little marv I may give that a shot, I just thought that it was a little fast for doing fence line, and the 719 had way lower gears for ground speed thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 7:11pm
Marv and Bill, its not the ground speed that is the problem. As Matt pointed out, it is the PTO speed. The cone clutch on your 700 series will drive the sickle bar mechanisms much faster than they were designed for. Sickle mowers are prone to damage when they are run in an overspeed condition. Most of the parts are no longer available so its not worth taking the chance with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildbill26 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 7:26pm
Chris, I under stood that from your first post, but the only reason I wanted to switch was because the 710 had a slower ground speed, and marvs idea with the drive pulley would slow it down ground speed wise so I wouldn't need to switch tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 8:56pm
I'm pretty sure he meant ground speed.
I slowed down my B-10 for tilling. This summer I got a sickle mower for the WD and that tractor has the same problem. If you get the revs up a little bit to get the sickle moving fast enough, even in first gear the tractor moves too fast, unless your in a perfectly manicured flat field.
Fixing that will be way more than swapping a pulley....
My old man told me Allis's have always been fast when it comes to ground speed. I guess it even applies to garden tractors.
At any rate, I've read in several places that a sickle mower on an old Simplicity or Allis should be run at half throttle maximum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2014 at 9:00pm
With that big pulley on the trans upping the torque, and the tiller hanging off the back, you can't ease off the clutch enough to get rolling without the front end coming off the ground. Kind of funny to see.
With a sickle hanging under the middle you probably won't have that problem.
Michigan farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michigan farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2014 at 6:22am
I just bought a sickle mower for my 616.
Came with the manual.
I will be reading it soon and will post any do's and don'ts
concerning proper operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2014 at 9:01pm
I'm sorry Marv, I overlooked the fact he still posessed the B-12.  The low speed pulley looks like a good idea. I did find when using mine I had to move quickly (2nd or 3rd gear) to keep the cut grass from falling in front of the sickle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2014 at 9:28pm
I call that modification "poor mans Hi Low" because its a lot cheaper than coughing up $200 or more for a hi low for one of these.
I would like a sickle mower, but you can't snag one for less than 3 or 4 hundred dollars around here.
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2014 at 8:40pm
I have a sickle mower on my HB112 and use it as much as possible, I had it on my B10 at first but, like Bill, found the ground speed too fast when I tried mowing next to trees or a fence.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
timflury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timflury Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2014 at 2:53pm
There are Simplicity Mfr. numbers for the larger diameter pulley/belt combinations.
The parts are in stock at your local TSC. You can also buy an arbor and separate pulley to sreate your own and weld the two pieces together.
The larger pulleys help a great deal when running the tiller.
There is a caution in the manual that says not to run the engine at more than half throttle when cutting with the sickle bar.
A friend of mine ran his up just briefly to show us how much the thing shakes.
When was the last time you thanked a veteran.
This page was generated in 0.219 seconds.
