720 followed me home today
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 720 followed me home today
    Posted: 19 Nov 2013 at 3:23pm
Got my 720 home today. It was in Sioux City, Ia. About 120 mile round trip. What do I need to make the rear PTO functional? PTO does not go in gear when I flip switch. It has a charging problem, that may have something to do with it. Wanted one along time, finally have it. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
ACook View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACook Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2013 at 3:31pm
First take the cover off in front of the seat and make sure the rear pto shaft and clutch haven't been removed.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2013 at 3:34pm
Nice find! You'll need to check pto switch for power and if switch is working. Then check for power at the clutch. Easy way to check clutch is run a hot wire to it. If it clicks and engages it's normally ok.
And as ACook said maybe shaft and clutch isn't there? Have seen that before!
Edited by farmtoybuilder - 19 Nov 2013 at 3:36pm
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2013 at 8:46pm
I believe that's a 720 special,like mine does not have pto shaft to it,it was a option on these,factory orange deck tells me its a special,a lower cost 720 fewer options
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2013 at 8:51pm
I don't think that is a special because it has the dual hydraulic levers and the three point hitch rockshaft.   Now both of these items can be added from a salvage tractor but if they are like my 720 special, I added the rockshaft so I could have the three point on it but left the hydraulics on the single lever.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2013 at 8:57pm
its just how mine came equipped,like I said u could get any of the options some have all some have fewer,plus I have tons of factory brochures on this subject that tell me that,i have sought out any literature for years on these tractors and have found some rare stuff
